use parameters in ilogic that haven't been created yet
neodd70
neodd70
I am trying to create an external Form that has a button that when the user clicks it, it will run an external rule to create parameters in the part it is being used on. Then those parameters can then be used in another external rule to create a sketch, add a circle and extrude cut the circle from the part. The problem I am having is that I get an error until I open the external rule that tries to use the newly created parameters and then save it almost like it isn't seeing that the parameters are there until I edit the rule. Is there a way I can fix this or is there another way I can use a variable from a rule in a Form?
Sergio.D.Suárez
Hello, Could you attach your code to analyze it?
If you have confidential information, try to replicate the error in a simplified format. Perhaps the error is in the way in which the parameters are accessed. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
neodd70
@Sergio.D.Suárez  Here are the two rules I have. First is the rule to create the parameters
Dim oPartDoc As Document = ThisDoc.Document
Dim oPartCompDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
If oPartDoc.DocumentType = kPartDocumentObject Then
Dim oParams As Parameters = oPartCompDef.Parameters
		Dim oUserParams As UserParameters = oParams.UserParameters
		Try
			oHoleSizes = oUserParams.Item("HoleSizes")
			Catch
oInsulationType = oUserParams.AddByValue("HoleSizes", 0, kInchLengthUnits)
MultiValue.SetList("HoleSizes", .109375, .125, .15625, .1875, .21875, .28125)
			End Try
		Try
			oMaterial = oUserParams.Item("MaterialType")
			Catch
oInsulationType = oUserParams.AddByValue("MaterialType", " ", kTextUnits)
MultiValue.SetList("MaterialType", "Starboard", "Acrylic", "Proboard")
			End Try
		Try
			oHoleType = oUserParams.Item("HoleType")
			Catch
oInsulationType = oUserParams.AddByValue("HoleType", " ", kTextUnits)
MultiValue.SetList("HoleType", "Pilot", "Thru", "Custom")
			End Try
		Try
			oFromFrontEdge = oUserParams.Item("FromFrontEdge")
			Catch
oInsulationType = oUserParams.AddByValue("FromFrontEdge", (0.25 * 2.54), kInchLengthUnits)
			End Try
		Try
			oFromLeftEdge = oUserParams.Item("FromLeftEdge")
			Catch
oInsulationType = oUserParams.AddByValue("FromLeftEdge", (1.125*2.54), kInchLengthUnits)
			End Try
		Try
			oFromRightEdge = oUserParams.Item("FromRightEdge")
			Catch
oInsulationType = oUserParams.AddByValue("FromRightEdge", (1.125*2.54), kInchLengthUnits)
			End Try
Parameter.UpdateAfterChange = True
MultiValue.UpdateAfterChange = True
next is a rule that needs to use those parameters to create a sketch of circles and extrude them. The parameters created by the first rule are what I want to have in a form.
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
'get measurements to determine Material Thickness
My_x = Measure.ExtentsLength
My_y = Measure.ExtentsWidth
My_z = Measure.ExtentsHeight
'Make longest value the Length, rounded to 4 places
oThickness = Round(MinOfMany(My_x, My_y, My_z), 4)
Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Holes")
Dim oFrontEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Front Edge of Pattern")
Dim oVertex As Vertex = oFrontEdge.StartVertex
Dim oLeftEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Left Edge of Pattern")
Dim oRightEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Right Edge of Pattern")
oMaterial = MaterialType
oHoleType = HoleType
oHoleSize = HoleSizes * 2.54
Dim oSketch As PlanarSketch
'oSketch = oPartCompDef.Sketches.AddWithOrientation(oFace, oFrontEdge, True, True, oVertex, False)
oSketch = oPartCompDef.Sketches.Add(oFace, False)
oSketch.AxisEntity = oFrontEdge
oSketch.OriginPoint = oFrontEdge.StartVertex
Dim oSketchNameSuffix As Integer
Dim oNameCompare As String
Dim oNameNumCount As Integer
Dim oNameCharCount As Integer
If oHoleType = "Thru" Then
	oSketchNameSuffix = 0
	oNameCompare = "SK_Hole_"
	oNameCharCount = 8
	oNameNumCount = 9
Else If oHoleType = "Pilot" Then
	oNameCompare = "SK_Pilot_"
	oNameCharCount = 9
	oNameNumCount = 10
	For Each oSketchNameCheck As Sketch In oPartCompDef.Sketches
		If Left(oSketchNameCheck.Name,oNameCharCount) = oNameCompare Then
			oSketchNumber = Val(Mid(oSketchNameCheck.Name, oNameNumCount, 2))
	        While oSketchNameSuffix <= oSketchNumber
				oSketchNameSuffix = oSketchNameSuffix + 1
			End While
	Next
oSketch.Name = oNameCompare & oSketchNameSuffix
Dim oQty = 4
oFromLeftEdge = FromLeftEdge * 2.54
oFromRightEdge = FromRightEdge * 2.54
oFromFrontEdge = FromFrontEdge * 2.54
Dim oFrontEdgeDistance = ThisApplication.MeasureTools.GetMinimumDistance(oFrontEdge.StartVertex, oFrontEdge.StopVertex)
Dim oPatternSpacing = (oFrontEdgeDistance -(oFromLeftEdge + oFromRightEdge)) / (oQty-1)
Dim oSketchPoint As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(oFromLeftEdge, oFromFrontEdge))
Dim circleParentSketch As PlanarSketch = oSketchPoint.Parent
Dim vectorForCheck As UnitVector = circleParentSketch.PlanarEntityGeometry.Normal
Dim pointToCheck As Point = oSketchPoint.Geometry3d
Dim foundObjects As ObjectsEnumerator = Nothing
Dim locationPoints As ObjectsEnumerator = Nothing
oPartCompDef.FindUsingRay(pointToCheck, vectorForCheck, .00001, foundObjects, locationPoints)
If (foundObjects.Count = 0) Then
	oSketch.NaturalAxisDirection = True
Else If (foundObjects.Count > 0) Then
	oSketch.NaturalAxisDirection = False
oSketchPoint.Delete
For i = 0 To oQty-1
	Dim oCircle As SketchCircle = oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(oFromLeftEdge + (i * oPatternSpacing), oFromFrontEdge), (oHoleSize/2))
Next
Dim oProfile As Profile = oSketch.Profiles.AddForSolid
Dim oExtrude As ExtrudeFeature = oPartCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, oThickness*2.54, kNegativeExtentDirection, kCutOperation)
