KEYCOLUMN VS MAPPED PROPERTY IV2019 - IS THIS A KNOWN ERROR?
Mark_Acton
Mark_Acton
I cannot figure out how to get my custom content center authored and published part(s) to populate the size and material pull downs with the correct information.  The part number is also adding an index number even though it has unique part numbers specified.
I understood that the family table column "Designation" mapped to Project.Size.Designation was supposed to be the default for "Size" in the dialog box, but it appears that "key columns" are overriding.
So where do I set "expressions" for "Filename", "Size",  "Material" and etc?
Thanks in advance
FG-INSERT DIALOG BOX.pngFAMILY TABLE-DESIGNATION.pngFAMILY TABLE-FILENAME.png
Mark_Acton
TTT (is that acronym still used Smiley Wink  ) as last week was a short week for most
Mark_Acton
Not takers eh?   Is that because it is so simple I should know and nobody wants to point that out?  Or is it really that complicated?  or nobody knows?
The example dialog is from Frame Generator.  I did not specifically say that in the original post, it was in the picture.
ttt
jan_priban
hope image explains
Size is family key column
File name is defined when frame is being place by Frame Generator - FG_FileName.jpg
Material combo is filled by frame Generator, material does not have to be filled in family table
Regards
Jan Priban
Mark_Acton
Hi, and thanks for the reply. Kelly Young with the Autodesk Technical
Support Team has kindly submitted this to development for review. However
I would like to explore your reply (see in blue below).
But first, what version are you using? Maybe its fixed in 2020. idk.
The question is "So where do I set "expressions" for "Filename", "Size",
"Material" and etc?"
hope image explains
Try This......make one of your other columns (or a couple columns) KEY
columns or create a couple KEY columns with some nonsense data . then
insert the FG part and notice the change in your size. I think that will
explain that issue.
Yes, found at the application options level. I'm looking to see if I can
use filename information that I already have in the Ipart.
Yes, I can select but the material wont change for this particular family,
so I wanted to set it as that material and not have a choice.
Regards
Jan Priban
footnote: Because you asked a question, it got me looking into the issue
again and I have figured out a work around - Thank You for replying. If
anyone cares to read this and wants the work around, email me. Its pretty
simple after one makes the connection.
jan_priban
Hi Mark,
I can comment KEY COLUMNS:
The Size combo-box in Frame Generator Insert dialog is based on Family Table KEY Columns. In CC Editor you can modify list and order of KEY columns. All KEY columns appear in FG Insert dialog. So one way is to use more KEY columns. Second way (my suggestion) is to use one column as KEY column and define formula based on other columns. This allows you to modify string as you need including spaces/special_characters.
Material and File name:
Just repeat what has been said. CC Material column has no relation to Material in FG Insert dialog, same with filename. FileName column defined in CC Family Table rides files name when frame is manually place into assembly by Place from Content Center, Frame Generator uses different "Place" and rides filename own way.
Regards
Jan Priban
