Open selected part of assembly in VBA
shastu
Advisor Advisor
shastu
If I have an assembly open and in the browser or from within the window have a part or assembly selected, what would be the VBA code to open the selected file and then close that file again?
MechMachineMan
 Sub Main()
Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc Is Nothing Then Exit Sub End If Select Case True Case Not oDoc.ActivatedObject Is Nothing If oDoc.ActivatedObject.Type = ObjectTypeEnum.kDocumentObject Then Set oDoc = oDoc.ActivatedObject Else MsgBox ("Invalid active object") Exit Sub End If Case oDoc.ActivatedObject Is Nothing 'Continue without revising anything Case Else MsgBox ("Invalid Activated Object!") End Select Dim oSS As SelectSet Set oSS = oDoc.SelectSet Select Case True Case oSS.Count = 0 Call ToggleWP(oDoc) Case oSS.Count = 1 If oSS.Item(1).Type = ObjectTypeEnum.kDocumentObject Then MsgBox (oSS.Item(1).Type) Call ToggleWP(oSS.Item(1)) ElseIf oSS.Item(1).Type = ObjectTypeEnum.kComponentOccurrenceObject Or oSS.Item(1).Type = ObjectTypeEnum.kComponentOccurrenceProxyObject Then Call ToggleWP(oSS.Item(1).Definition.Document) Else MsgBox ("Invalid selected object!") End If Case oSS.Count > 1 For Each oItem In oSS If oItem.Type = ObjectTypeEnum.kDocumentObject Then ToggleWP (oItem) End If Next Case Else MsgBox ("Invalid Select Set!") End Select End Sub Sub ToggleWP(oDoc As Document) Set oNewDoc = ThisApplication.Documents.Open(oDoc.FullFileName, True) 'oNewDoc.Close End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
shastu
Fantastic.  I really wish I could figure this stuff out on my own instead of asking for help all the time.  I tried to make sense of using the Object Browser, but just can't get my head wrapped around it.  Thanks SO MUCH!!!
MechMachineMan
The object model might be easier for you to understand where certain parentage of various functions/features exist.
http://help.autodesk.com.s3.amazonaws.com/sfdcarticles/kA23A000000PR5fSAG/Inventor2016ObjectModel.pd...
Justin K
shastu
Thanks for your help,  I have seen the model before, but I don't understand how to use it.  For example,  I now have a program that opens the file that they had selected, saves it off as a different filename, updates some iproperties and then closes the files.  Now I want to replace the exact occurrence that they had selected with the new filename.  I have all the information passed from one sub to another, but how do I capture the exact occurrence that they had selected and reselect it.  Also how do I replace the component assuming I still have all file location and information still?  I assume I need to capture the selection set somehow, and then do a replace, but using the model, I don't know the exact nomenclature to make it work.
shastu
Here is what I am needing.  Down at the bottom I have the FullFileName of the document that was selected and it will show up in the Msgbox oDoc.FullFileName.  The very next line I need to capture the occurrence name and then use that later to reselect that same occurrence.
Sub Main()
        Exit Sub
    Select Case True
            Else
                Exit Sub
        Case Else
    End Select
    Select Case True
        Case oSS.Count = 0
            Call ToggleWP(oDoc)
        Case oSS.Count = 1
            Else
        Case oSS.Count > 1
                MsgBox "You should only select one item at a time before using the button just used"
                    ToggleWP (oItem)
            Next
        Case Else
    End Select
End Sub
Dim oCompOccur As Inventor.ComponentOccurrence
'Set oCompOccur = oCompOccur.name
MsgBox oDoc.FullFileName
MsgBox oCompOccur.name
End Sub
MechMachineMan
 Sub Main()
        Exit Sub
    Select Case True
            Else
                Exit Sub
        Case Else
    End Select
    Select Case True
        Case oSS.Count = 0
            Exit Sub
        Case oSS.Count = 1
            Else
        Case oSS.Count > 1
                If oItem.Type = ObjectTypeEnum.kComponentOccurrenceObject Or ObjectTypeEnum.kComponentOccurrenceProxyObject Then
                    ToggleWP (oItem)
            Next
        Case Else
    End Select
End Sub
Sub ToggleWP(oOcc As ComponentOccurrence)
         Set oNewDoc = ThisApplication.Documents.Open(oOcc.Definition.Document.FullFileName, True)
         MsgBox(oOcc.Name)
         'oNewDoc.Close
End Sub
Justin K
