Replacing the title block on all drawing sheets
brow1372
brow1372
Hi All,
I am trying to patch together some Ilogic code to delete and replace the title blocks on every sheet in a drawing.
I am stuck at the point that it should go through all the sheets and add the new title block.
Thanks for the help.
SyntaxEditor Code Snippet
         Dim oDoc As Inventor.Document
        oDoc = m_inventorApp
        ' Find out if TitleBlockDefinition exists
        Dim bTBDfound As Boolean
        bTBDfound = False
        Dim oTBD As TitleBlockDefinition
        For Each oTBD In oDoc.TitleBlockDefinitions
            Debug.Print(oTBD.Name)
            If oTBD.Name = "HMCTITLE" Then
                bTBDfound = True
                Exit For
        Next oTBD
'        If bTBDfound = False Then'            MsgBox("ANSI - Large Title block already deleted")'            End'        End If
        oTBD = oDoc.TitleBlockDefinitions("HMCTITLE")
        If oTBD.IsReferenced = True Then
            Dim oSheetFormat As SheetFormat, oSheet As Sheet
            ' Check if there is any instance in SheetFormat/Sheet
            ' that refers to the TitleBlockDefinition
            For Each oSheet In oDoc.Sheets
                If oSheet.TitleBlock.Definition Is oTBD Then
                    ' Delete this instance which refers to the
                    ' TitleBlockDefinition
                    oSheet.TitleBlock.Delete()
            Next
            For Each oSheetFormat In oDoc.SheetFormats
                If oSheetFormat.ReferencedTitleBlockDefinition Is
                  oTBD Then
                    oSheetFormat.Delete()
            Next
            ' Now you can delete the TitleBlockDefinition.
            oTBD.Delete()
        Else
            ' TitleBlockDefinition is not referenced go ahead and
            ' delete
            oTBD.Delete()
ThisDrawing.ResourceFileName = "z:\templates\HMC DRAWING.idw"
ActiveSheet = ThisDrawing.Sheet("Sheet:1")
ActiveSheet.TitleBlock = "HMCTITLE"
'ActiveSheet = ThisDrawing.Sheet("Sheet:2")
'ActiveSheet = ThisDrawing.Sheet("Sheet:3")'ActiveSheet.TitleBlock = "HMCTITLE"
iLogicVb.UpdateWhenDone = True
MessageBox.Show("Success", "Iproperty update", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Curtis_Waguespack
HI @row1372,
Here's a quick example, that uses title block definitions that are already in the file, and swaps one for another.
It was unclear to me what your goal was here.
Are you trying to delete all existing title blocks in the drawing, including those in the sheet formats, and then delete the title block definition, so that you can bring in a new version of the title block definition from another file, and insert it onto each sheet?
If that's the case then I think you're still missing some stuff.
I hope this helps.
Curtis
oInput = InputRadioBox("Select One", "B SIZE", "D SIZE", True, "iLogic")
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
Dim oCurrentNumber  As Sheet
oCurrentNumber = oDoc.ActiveSheet
' Iterate through the sheets
Dim oSheet As Sheet
	oSheet.Activate
	If oInput = True Then
		ActiveSheet.TitleBlock = "B SIZE"
	Else
		ActiveSheet.TitleBlock = "D SIZE"
Next
'return to starting sheet
oCurrentNumber.Activate
'[ optional to collapse nodes
Dim oNode As BrowserNode
For Each oNode In oDoc.BrowserPanes.ActivePane.TopNode.BrowserNodes
	' If the node is expanded, collapse it.
	If oNode.Expanded = True Then
		oNode.Expanded = False
Next
brow1372
Thanks for the reply.
Yes I am deleting all references and instances of the existing title blocks and that part works fine.
At the very end where it says
 is where I want it to add the title block from the new resource file and what I show here works.
My goal is to make it work no matter how many sheets I have.
I have tried to put some of the examples into practice without much luck.
Clearly I am almost illiterate when it comes to Ilogic code writing so I just need a little hand holding for this last bit.
Thanks again.
brow1372
Ok I think I figured it out.
This is what I came up with taken from your first response.
        Dim oSheet1 As Sheet
        For Each oSheet1 In oDoc.Sheets
        oSheet1.Activate
            Next
Thanks again
Lennart_Losjo
Hi. Do you have this code working without problems?
Will you please provide the complete code for me?
Sorry if this thread is outdated.
Senior Product Specialist
Fusion 360, Inventor.
