Unfold error
Unfold error
b.graaf
Unfold error
b.graaf
I have a piece of C# code, to unfold a sheet metal part.
I would like to unfold it, without opening the file.
The next lines
PartDocument invDoc = _inventApp.Documents.Open(fileToExport, false) as PartDocument;
SheetMetalComponentDefinition scd = (SheetMetalComponentDefinition)invDoc.ComponentDefinition;
if (scd.HasFlatPattern)
    // Something....
else
    try
    scd.Unfold();
    // Something...
catch
    _errorDetected = true;
This gives me an error on the scd.Unfold() method.
If I change:
to:
PartDocument invDoc = _inventApp.Documents.Open(fileToExport, true) as PartDocument;
the unfold is successfull.
The strange thing is, that if I have an assembly openend en with the code I itterate through all the parts within this assembly, than the unfold method works, if I use the false option in:
But if I am in document X and try the code on document Y, then I have to use the "true" option....
Somebody an idea?
adam.nagy
Autodesk Support
Autodesk Support
I guess some parts necessary for the unfold get loaded when the sheet metal is visible, even if just as part of the assembly document.
This limitation has been around for a while:
http://forums.autodesk.com/t5/inventor-customization/unfold-api-fails-on-inventor-2013-sp1-1/td-p/37...
Which Inventor version are you using?
Cheers,
Adam Nagy
Autodesk Platform Services
b.graaf
Hello Adam,
Sorry for my late reply and thank you for yours!
I am trying this with Inventor 2017.3
Best Regards,
Branko.
adam.nagy
Autodesk Support
Autodesk Support
Thank you, Branko!
I updated the log with this info.
For your reference, the issue id is #170081
Adam Nagy
