Open model from drawing [VBA]
Message 1 of 9
Hi All,
Simply I need to open the model (ipt/iam)from the drawing with VBA
Public Sub Test_Click()
Dim oDocument As Inventor.DrawingDocument
    Set oDocument = ThisApplication.ActiveDocument
    ThisApplication.Documents.Open(ThisDrawing.ModelDocument.FullFileName)
End Sub
Could any one help my with the simple soution ? The code abowe dosent work
Replies (8)
Message 2 of 9
MechMachineMan
Dim oDwgDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
Dim oModelDoc As Document
For Each oSheet In oDwgDoc.Sheets
oSheet.Activate
oDrawingView = oSheet.DrawingViews.Item(1)
oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
ThisApplication.Documents.Open(oModelDoc.FullDocumentName, True) ' False for invisbly opened
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
Hi
Thank you for the help...but i am getting the error:
2015-04-23 19_57_48-Microsoft Visual Basic for Applications - 09042015.ivb [running] - [ExportFromID.jpg
Message 4 of 9
MechMachineMan
Hmmm. Not at clue. It works perfectly for me just like that inside of inventor.
It could be because it is written in vb.net instead of vba, so it might be missing Call in front of the last line.
Justin K
Message 5 of 9
Yes, it works as Ilogic rule (VB.Net) but I need this for my macro so i need this in VBA.....
Message 6 of 9
MechMachineMan
And that's where you get to have fun with it 🙂 I'm clueless as to how vba
would be written different
Justin K
Message 7 of 9
Ok i didi it 🙂
    Set oDwgDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet.Activate
Set oDrawingView = oSheet.DrawingViews.Item(1)
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Call ThisApplication.Documents.Open(oModelDoc.FullDocumentName, True) ' False for invisbly opened
Next
 And it works 🙂
Thanks for help
Message 8 of 9
MechMachineMan
Pretty Simple, so it was just adding "Set" And "Call" to convert it?
Justin K
Message 9 of 9
Yes 🙂
