Open .dwg with iLogic
keithjk
keithjk
Is it possible to open a .dwg file with Inventor?  I want to open my assembly .dwg and pass some custom iProperties to it.
Sure it's possible,
ThisApplication.Documents.Open("Full file path + extension here")
How do you want to pass some custom iProperties to it?
keithjk
Jefkee,
Thanks, I figured it out yesterday and I figured out how to pass the iPoperties also.  (I have a LISP and .NET background so iLogic is knew to me.)
It appears to me that iLogic can use many .NET functions?
and it's possible to open autocad file with autocad in inventor?
MechMachineMan
If your file assosciation defaults are set to open .dwg's with autocad, this should work:
Process.Start("C:\FileName.dwg")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks MechMachine 🙂
