OnPopulateFileMetadata - which command trigged the event
stefan.palm
stefan.palm
Would it be possible to, via the OnPopulateFileMetadata event arguments, figure out which command triggered the event?
bradeneuropeArthur
Don't know if that is possible.
I will have a look.
I am using the userinputevents to trigger the command name first.
Then I use the populatefilemetadata event....
Maybe this already helps you?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
stefan.palm
Thanks for quick reply.
I found what i needed --> CommandManager.ActiveCommand.
antoniobaron
This info is for Addin development hope its useful even if it's a little bit late.
Public Sub Active()
m_FileUIEvents = m_inventorApplication.FileUIEvents
' replace meventsobj by the inventor
AddHandler m_inventorApplication.FileUIEvents.OnPopulateFileMetadata, AddressOf m_fileUIEvents_OnPopulateFileMetadata
Public Sub m_fileUIEvents_OnPopulateFileMetadata(ByVal FileMetadataObjects As Inventor.ObjectsEnumerator, ByVal Formulae As String, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_FileUIEvents.OnPopulateFileMetadata
HandlingCode = HandlingCodeEnum.kEventHandled
MsgBox("Testing 1 2 3")
Dim oMetaData As FileMetadata
If FileMetadataObjects.Count > 0 Then
For Each oMetaData In FileMetadataObjects
'suggest custom name
oMetaData.FileName = "asdk_" & oMetaData.FileName
oMetaData.FileNameOverridden = True
Next oMetaData
'tell Inventor the event is handled
End Sub
https://spiderinnet2.typepad.com/blog/2013/03/inventor-api-vbnet-fileui-events.html
