Incorrect RangeBox of Text-Emboss (when using some chars)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'd like to know why RangeBox size (Depth) of the part with embossed text varies depending on letters used.
See the sample attached (iLogic rule embedded shows message box with overall Sizes calculated based on RangeBox object).
Thickness of the base is 0.02mm
Emboss depth (Add) is 0.01mm
Expected overall Z-size is 0.03mm (0.003cm)
But in fact
Char "e" - 0.003
Char "s" - 0.0032
Char "a" - 0.0038
Inventor API issue?
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
Not sure to have understand you correctly.
Do you mean UI settings may have an influence on API functions?
I did not understand the question well.
Not sure but the letters themselves
I think it's changing ...
Maxim-CADman77
Could you confirm that iLogic rule embedded in IPT attached to the 1st message in this thread shows 0.0032 as Z size?
Maxim-CADman77
Could anybody confirm the behaviour I've described is reproducible on the sample I've shared?
(If necessary I can create sample for the earlier Inventor release, for ex. 2014)
