Check if user is connected to the vault
Hi community!
I'm developing a console app that communicates with Inventor 2017 by using the API. I'd like to check if the user is connected to the vault.
I've find that code but the VaultBase namespace does not exist.
https://adndevblog.typepad.com/manufacturing/2016/03/inventor-add-in-that-gets-the-status-of-a-file-...
Dim myConnection As VDF.Vault.Currency.Connections.Connection = Nothing
    ' Get the Vault connection from Inventor Vault log in
    myConnection =
        Connectivity.Application.VaultBase.ConnectionManager.Instance.Connection()
    If myConnection Is Nothing Then
        System.Windows.Forms.MessageBox.Show _
                            ("Unable to get Vault connection, logged into Vault?")
        ' Debug.Print("Unable to get Vault connection")
        Return
I added all references to Autodesk.Connectivity.* and Autodesk.DataManagement.*.
Pascal
bradeneuropeArthur
You could also take a look at the EDM add in!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JhoelForshav
Hi @Anonymous ,
Would this work for you?
AddReference "Autodesk.DataManagement.Client.Framework.Vault"
AddReference "Connectivity.InventorAddin.EdmAddin"
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports edm = Connectivity.InventorAddin.EdmAddin
Dim Connection As VDF.Vault.Currency.Connections.Connection = edm.EdmSecurity.Instance.VaultConnection()
If Connection IsNot Nothing
	MsgBox("Vault connection exists")
Else
	MsgBox("No Vault connection")
Thanks @JhoelForshav, it works like a charm but I had to add these references:
  • Autodesk.Connectivity.Extensibility.Framework.dll
  • Autodesk.Connectivity.WebServices.dll
  • Autodesk.Connectivity.WebServices.Interop.dll
  • Autodesk.DataManagement.Addin.Framework.dll
  • Autodesk.DataManagement.Addin.Vault.dll
  • Autodesk.DataManagement.Client.Framework.dll
  • Autodesk.DataManagement.Client.Framework.Forms.dll
  • Autodesk.DataManagement.Client.Framework.Vault.dll
  • Connectivity.Common.dll
  • Connectivity.InventorAddin.EdmAddin.dll
jjstr8
Any idea on how to refresh the connection status? If I lose the network connection to the Vault server, EdmSecurity.Instance.VaultConnection.IsConnected stays true.
MaciejWojda
I cannot find Connectivity.InventorAddin.EdmAddin.dll, do you know how to get it? I need it for Vault 2021
