OnCameraChange » Synchronous rotation of several models
I use Inventor 2021 and program individual functions for the CAD system using VB.Net in Visual Studio 2019.
My issue:
I would like to rotate two 3D-models (i. e. IPT or IAM) in Inventor synchronously in two windows.
For this purpose I included an EventListener, which reacts on the event "OnCameraChange" of one window and transfers the camera attributes to the other camera and then updates them with:
Camera2.ApplyWithoutTransition()(Inspiration: https://spiderinnet2.typepad.com/blog/2013/03/inventor-api-vbnet-camera-events.html)
Actually it works...
I rotate the model in the first window and the model in the second window is positioned exactly the same.
But the event is only fired when I finish rotating in the first window and the other model jumps into position immediately.
But I would like to rotate it synchronously. (SOLIDWORKS Tutorial – Compare Tool - YouTube ~2.00 min)
Is it possible to force the event to be fired permanently while I am rotating?
(I once implemented the same functionality in TypeScript with Three.js, where it worked fine with an EventListener.)
Apparently, what I want to realize is possible in fusion. Opening a New window to work on multiple views in same time? - Autodesk Community - Fusion 360
Unfortunately I don't have a fusion and I can't try it...
Is it possible to assign the same camera to several windows?
How else could one approach the matter?
Thanks in advance for your input.
Thanks and greetings
MB-Ing.
