Opening a New window to work on multiple views in same time?
Hi Everybody ,
I just discover the developing tool for Scripting in Fusion 360 and I need your help to solve a problem.
Actually i would like to work on a project and to see my piece , in the same time , from different angles (from the front AND from the Right for example) .
So i would like to know if it is possible , with an Add-in (or script) , to have a second window of the same project with only a difference of camera angle . I would like to move/modify/zoom on the piece and having the two windows moving at the same time (with just a difference of camera orientation) .
If you have any idea , i'll be very grateful and if you think the difficulty for doing that is too big i am also interested  😉
Thank you !
Jeremy
ekinsb
Fusion has the ability to show either one view or four views of your part.  With four views you can look at your part from four different angles.  By default you will see a front, top, right, and isometric view.  There is an option to sync the orthographic views so if you zoom or scroll in one view, the others will do the same.  You don't need any scripting for this but use the commands in the NavBar as shown below.
Brian Ekins
Mod the Machine blog
