How can write rule for Sheet metal assembly export dxf with file name Part Number_sheet thickness_quantity
Hi
I want  rule of Sheet metal assembly export dxf with Blue Bend line  but, File name is part Number_Thickness_Quantity.
İt is possible by rule
JelteDeJong
hi,
You can try the next rule. I did have some problem with getting the qty. but the rest should work.
Sub main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    For Each oDoc As Document In doc.AllReferencedDocuments
        If (oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For
        Dim fileName As String = getFileName(oDoc)
        Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
        If oCompDef.HasFlatPattern = False Then
            oCompDef.Unfold()
        Else
            oCompDef.FlatPattern.Edit()
        Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayerColor=0;0;255&BendDownLayerColor=0;0;255&InvisibleLayers=IV_TANGENT"
        oCompDef.DataIO.WriteDataToFile(sOut, fileName)
		oCompDef.FlatPattern.ExitEdit()
    Next
End Sub
Private Function getFileName(oDoc As PartDocument) As String
    Dim fileNameDoc = System.IO.Path.GetFileName(oDoc.FullFileName)
    Dim partNumber = iProperties.Value(fileNameDoc, "Project", "Part Number")
	Dim thickness As Double = Parameter("flatpattern.ipt", "Thickness")
	thickness = Math.Round(thickness * 10)
    Dim newFileName As String = String.Format("{0}_{1}",partNumber, thickness)
    Return IO.Path.Combine("c:\temp\", newFileName)
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Firtstly Thanks for your repply.
I tried the your code, but it wasnt work.
"Parameter: The document named "flatpattern.ipt" was not found."  it show  error
JelteDeJong
I guessit was to later yesterday. there i found the bug and fixed it. Check the code below. An other thing that i forgot to mention. i multiply the thickness by 10. I did that because its better if you dont use points in file names. For example if your part would be 1.5mm thick you would get a file name like "PartNumber_1.5.dxf". this code will translate that to "PartNumber_15.dxf"
Sub main()
            oCompDef.Unfold()
        Else
    Next
End Sub
    Dim thickness As Double = Parameter(fileNameDoc, "Thickness")
End Function
Jelte de Jong
Thanks for your attentions. @JelteDeJong
The your rule give:
Error in rule: dxf, in document: 0001-0.iam
c (Exception from HRESULT: 0x80004005 (E_FAIL))
 More İnfo
System.Runtime.InteropServices.COMException (0x80004005): System.Runtime.InteropServices.COMException (0x80004005): Belirtilmemiş hata (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.FlatPattern.Edit()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule) (Exception from HRESULT: 0x80004005 (E_FAIL))
at ThisRule.Main()
JelteDeJong
That message doesn't say much. So that does not help. but i added a try/catch block. this will show the file that is creating the problem. maybe it helps. try this rule.
Sub main()
		Try
	            oCompDef.Unfold()
	        Else
        Catch ex As Exception
			MsgBox("Exception was thrown while exporting file: " & oDoc.FullDocumentName )
        End Try
    Next
End Sub
End Function
Jelte de Jong
