iLogic - Change Layer Appearance color
Hi all,
In active sheet, I would like an Ilogic code to change Layer Appearance color to black. I have several drawings where some symbols and lines are blue. I want everything to be black.
Now I have to manually choose 'Edit view annotation style'. Then select 'Layers' and then change all Appearance colors that are blue to black..
Hope this is possible 🙂
lmc.engineering
Hi @Anonymous
You can do this using the following:
Dim drawdoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oLayers As LayersEnumerator
oLayers = drawdoc.StylesManager.Layers
Dim oColor As Color
oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
Dim oLayer As Layer
For Each oLayer In oLayers
	oLayer.Color = oColor
Next
Thank you! Appreciate your help!
ysbaodnj
I'm looking for a layer color change ilogic code and I'm asking for help.
I found an ilogic code to change the color of a layer, but the color of all layers drawn on the drawing is changed.
I want to know how to change only the layer color of a specific leader text.
Thank you for your help.
