2016 colorize surfaces ipt with ilogic
mgeurts
Message 1 of 13
mgeurts
Does anybody know if it is possible in Inventor 2016 to colorize all surfaces in one color from an ipt with ilogic?
Inventor Professional 2021
3DS Max 2022
Win 10
Replies (12)
Message 2 of 13
leowarren34
Hi @mgeurts,
Are you after having each part in a different color - this was an idea floating around on the idea station and somebody had made a vba macro - if this is what you are after https://forums.autodesk.com/t5/inventor-ideas/visual-style-every-part-with-different-color/idi-p/871...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 13
mgeurts
Thanks for your reply but it is not what I'm looking for.
An ipt as raw casting is machined in an iam. The machined surfaces must be red so with real painting it will be obvious which surfaces to paint and which not.
Now I make the material from the ipt red and then manually all surfaces gray through Properties, so in the iam the machined surfaces come out red again.
To give manually all surfaces a different color is time consuming, therefore the question if it is possible to do this in 2016 with ilogic.
3DS Max 2022
Win 10
Message 4 of 13
JhoelForshav
Hi @mgeurts
Do I understand correctly that you want to color every face in a part from an iLogic rule within the part (In part environment)
Try something like this:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oStyle As RenderStyle = oDoc.RenderStyles("Red")
For Each oSolid As SurfaceBody In oDoc.ComponentDefinition.SurfaceBodies
	For Each oFace As Face In oSolid.Faces
		oFace.SetRenderStyle(kOverrideRenderStyle, oStyle)
	Next
Next
That will color every face in the part red.
Message 5 of 13
mgeurts
Hi, @JhoelForshav
Thanks for your reply.
Yes, that's exactly what I'm looking for but I'm complete noob at this.
Anyway managed to run it but got an error:
3DS Max 2022
Win 10
Message 6 of 13
JhoelForshav
Message 7 of 13
mgeurts
I didn't realize that pics were not uploaded:
3DS Max 2022
Win 10
Message 8 of 13
JhoelForshav
@mgeurts
Maybe you dont have the renderstyle "Red"...
Does this work then? 🙂
Dim oRenderStyles As RenderStyles = oDoc.RenderStyles
Dim oName As String = "Red_Color"
Dim styleExists As Boolean = False
Dim myStyle As RenderStyle
For Each oRenderStyle As RenderStyle In oRenderStyles
	If oRenderStyle.Name = oName
		styleExists = True
		myStyle = oRenderStyle
		Exit For
Next
If Not styleExists
	myStyle = oRenderStyles.Add(oName)
	myStyle.SetAmbientColor(255, 0, 0)
	myStyle.SetDiffuseColor(255, 0, 0)
For Each oSurfBod As SurfaceBody In oDoc.ComponentDefinition.SurfaceBodies
	For Each oFace As Face In oSurfBod.Faces
		oFace.SetRenderStyle(kOverrideRenderStyle, myStyle)
	Next
Next
Message 9 of 13
mgeurts
Now I got this reporting:
The first one made me check if I have all service packs. Autodesk Desktop App is telling I'm up to date but in Inventor I don't see any SP's installed:
Tried to install SP1 doesn't do anything and when I ty to install SP2 it says to install SP1.
Considering ilogic: I opened Add Rule and pasted the code, after OK I got the error.
ipt attached.
3DS Max 2022
Win 10
Message 10 of 13
JhoelForshav
@mgeurts
Maybe it doesn't get the StyleSourceTypeEnum correct with just kOverrideRenderStyle...
Could try changing it to this:
  styleExists = True
  Exit For
Next
If Not styleExists
  oFace.SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, myStyle)
 Next
Next
Or this:
  styleExists = True
  Exit For
Next
If Not styleExists
  oFace.SetRenderStyle(37123, myStyle)
 Next
Next
It works for me in 2020 either way - See screencast. I can't test in 2016 though...
Message 11 of 13
mgeurts
Good morning!
Both codes are working. Many thanks for your effort.
Have a nice day
3DS Max 2022
Win 10
Message 12 of 13
JhoelForshav
@mgeurts
Happy to help! I guess that was the problem with the first code i posted also then...
So something like this probably works as well?
		oFace.SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oStyle)
	Next
Next
Message 13 of 13
mgeurts
Yes, this one works also.
Thanks again!
3DS Max 2022
Win 10
