We have a home-grown Inventor addin (2017) that is executed within an assembly. It creates a new part (a cable) and then places it, along with some cable clamps. If executed a second time (let's say something changed slightly in the cable routing), it first searches for any existing cables and clamps and deletes them before doing its thing. All works well for a dozen designers. The problem is that for 3 designers, while the subsequent execution deletes the clamps, it does NOT delete the cable (and this causes problems later in the program). Same software, same DLL, same workflow, different results. Actually, this problem has dogged us for years, through several software upgrades, as well as hardware changes.
In the course of troubleshooting, one recent thing we tried was to export the Application Settings from a "working" PC, then import them into a "non-working" PC, but to no avail. At the same time, we can't help but think it's some setting we've overlooked somewhere.
Are there any gurus out there with similar experiences, and hopefully, a timely suggestion?
Thanks in advance!
Software Programmer
Draper, Inc.
