Object reference not set to an instance - oCurrentNumber = oDoc.ActiveSheet
andrew_canfield
andrew_canfield
I'm pretty sure this was working Friday afternoon - test again Monday morning & an error's appeared!
Object reference not set to an instance of an object.
The problem is this line:
SyntaxEditor Code Snippet
ThisDrawing.ResourceFileName = "C:\Vault Views\PDM01\Templates\test1.idw"
ThisDrawing.KeepExtraResources = True
MessageBox.Show("Line 4", "Title")
Dim oDoc As DrawingDocument
MessageBox.Show("Line 8", "Title")
Dim oCurrentNumber  As Sheet
MessageBox.Show("Line 12", "Title")
MessageBox.Show("Line 16", "Title")
oCurrentNumber.Activate
 Regards
Andrew
bradeneuropeArthur
oDoc is not set!!!
oDoc = thisapplication.activedocument maybe?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
andrew_canfield
thanks
bradeneuropeArthur
Your thanks are appreciated.
have a nice day.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
