Need help with code for looping through the IDW and plotting a PDF per sheet.
Hi all,
I create IDW's with multiple sheets and I need to create seperate PDF's of each sheet.  I'm confused on the code to loop thru each sheet and create the PDF.
From there I should be able to create code to export each sheet as a DWG.
At an older company I know we had something like that.  Click to button and the program would cycle through all sheets and plot to PDF.  And save it to the currect IDW location.
MechMachineMan
Imports System.Diagnostics
Imports System.Threading
Sub Main
Dim oTextSave As String = "C:\Users\Filename"                            'Create a text doc and make this location match for post-processing info
Dim stopWatch As New Stopwatch()
	stopWatch.Start()
oWrite = System.IO.File.CreateText(oTextSave)
oWrite.WriteLine("References")
Dim oDwgDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
Dim oModelDoc As Document
Dim oMultiList As New List(Of String)
	oMultiList=FBrowseMulti
	For j=0 To oMultiList.Count-1
		'MsgBox(oMultiList.Item(j))
		oDoc=ThisApplication.Documents.Open(oMultiList.Item(j), False)
For Each oSheet In oDwgDoc.Sheets
	oSheet.Activate
	oDrawingView = oSheet.DrawingViews.Item(1)
	oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
	oWO = oModelDoc.PropertySets.Item("Inventor User Defined Properties").Item("WO#").Value
Next
Next ' Multi
	stopWatch.Stop()
Dim ts As TimeSpan = stopWatch.Elapsed
Dim elapsedTime As String = String.Format("{0:00}:{1:00}:{2:00}.{3:00}", ts.Hours, ts.Minutes, ts.Seconds, ts.Milliseconds / 10)
MsgBox("RunTime " & elapsedTime)
oWrite.Close
ThisDoc.Launch(oTextSave)
End Sub 'Main
Private Function FBrowseMulti
    Dim oFileDlg As FileDialog
    Call ThisApplication.CreateFileDialog(oFileDlg)
    With oFileDlg
        .FilterIndex = 1
        .MultiSelectEnabled = True
        .CancelError = True
           On Error Resume Next
            .Filter = "Inventor Files (*.idw;)|*.idw|All Files (*.*)|*.*"
            .DialogTitle = "Select .idw Files To Include In Drawing List"
            .ShowOpen
    End With
    If Err.Number <> 0 Then
        MsgBox("Error Exists")
   ElseIf Not oFileDlg.FileName = "" Then
        Dim fNames As Object
        fNames = Split(oFileDlg.FileName, "|")
        Dim curName As Object
        For Each curName In fNames
            oMultiList.Add(curName)
        Next curName
    End If
Return oMultiList
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
