Need help with an iLogic rule
mgrenier1
mgrenier1
I have an iFeature driven by an Excel spreadsheet, I have a parameter named Désignation in said spreadsheet that is used to drive the iFeature.
I used that iFeature twice in a multisolid Master.ipt file using a different Désignation each time. I used make component to create parts and an assembly after that. Is there a way to bring back the Désignation used in the iFeature to make the solids in Master.ipt in the new part as the part description using iLogic?
Maybe I built my Excel table wrong or something for this application, idk
I included the files I used down below.
I know content center is probably a better way to achieve this, but these engineers are stubborn with their multisolid workflow lol.
bradeneuropeArthur
You use two different i-features in one part and they have two different designations correct?
This seems to be a lack of this method which I have solved with similar problem with an add-in.
Or is your issue different?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mgrenier1
What add-in are you refering to?
bradeneuropeArthur
created myself:)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
but is my description the case or not?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
mgrenier1
I use the same iFeature to create both solids, but both are using a different value from the Excel spreadsheet
bradeneuropeArthur
that is a lack of this use case. I solve this via coding. otherwise i have no quick solution.
@johnsonshiue
@CGBenner
do you have?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
