Find Detached Balloons Not Working
gustavo.cassel
gustavo.cassel
I'm trying to find if some drawing documents have detached balloons.
But it seems that the .Attached property is not returning the correct value.
Here is the code that I have:
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Debug.Print oDrawDoc.ActiveSheet.Balloons.Count
    Dim LocalBalloon As Balloon
    For Each LocalBalloon In oDrawDoc.ActiveSheet.Balloons
        Debug.Print LocalBalloon.Attached
    Next LocalBalloon
And an image with a detached balloon, the property returns true.
jjstr8
The .Attached property's value is based on whether or not it is tied to a component, so the value you're seeing is correct.  It would be rare to have a detached one, since Inventor deletes balloons for components that are no longer in the referenced model.  If you want to know if the leader is attached to an edge (as opposed to loose positioned) check balloon.Leader.AllLeafNodes(1).AttachedEntity to see if there's a GeometryIntent it references.
JelteDeJong
I see that you are using VBA. I would advise you to start learning iLogic. You might want to read this post "Is VBA in Inventor obsolete?".
Your rule would then look something like this:
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
For Each LocalBalloon As Balloon In oDrawDoc.ActiveSheet.Balloons
    Dim nodes = LocalBalloon.Leader.AllNodes
    Dim lastNode = nodes.Item(nodes.Count)
    If (lastNode.AttachedEntity Is Nothing) Then
        logger.Info("Unattached node found")
Next
Jelte de Jong
Blog: hjalte.nl - github.com
gustavo.cassel
Hi @JelteDeJong, thanks for the reply, it worked well.
And for the VBA code, I only use for this small tests.
For me the VBA code editor makes easy to debug any function to study the API.
The detached balloon finder will be included in my add-in in C#.
Again, thanks for the reply! Helped a lot.
