Control Break Style via iLogic/VB.NET
ngdnam88
ngdnam88
Dears,
I'm trying setting the default style for Break View. Could you please help me the iLogic/VB.NET or key to control it?
Thank you very much!
WCrihfield
Hi @ngdnam88.  I don't think you can change the 'default' setting there.  You can certainly choose one of the two options when creating one, either manually, or by code, but I believe the default is hard coded by Inventor right now.  You can see this hint in the online help documentation for the method (BreakOperations.Add ) used to add a new BreakOperation to a DrawingView.  It uses the BreakStyleEnum to set which one you want to use, and tells us that the variation with the value of 84481 (kRectangularBreakStyle) is the default.
Wesley Crihfield
(Not an Autodesk Employee)
ngdnam88
Thanks for your help!
