iLogic Command to load full assembly for exiting expressmode
fabian.steinruck
Message 1 of 9
fabian.steinruck
in our iLogic Routine, we export the opened assembly as a STEP file.
In this existing rule we need to fully load the assembly before the export is happening, i couldn't find the command in the documentation about that.
Also, tried the EventWatcher, but without success.
How is the command called to fully load the assembly for exiting the express mode via iLogic?
Replies (8)
Message 2 of 9
Andrii_Humeniuk
Hi @fabian.steinruck . This code opens your assembly in full mode. Don't forget to write down the path to your file, line 4 (YourFile).
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Add("ExpressModeBehavior", "OpenFull")
ThisApplication.Documents.OpenWithOptions(YourFile, oOptions, True)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 9
fabian.steinruck
Sorry if I wrote my question a bit imprecise, the assembly is already opened.
So if we decided to export this assembly as an step while already opened, I need the full load command like pressing the full load button.
Message 4 of 9
Andrii_Humeniuk
I'm sorry, but I couldn't find a command that directly exits Express mode. I hope this code helps you.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim YourFile As String = oDoc.FullFileName
oDoc.Close()
Dim expressDoc As AssemblyDocument = ThisApplication.Documents.OpenWithOptions(YourFile, oOptions, True)
Message 5 of 9
fabian.steinruck
The sequence with close and reopen the Doc works but takes to long for the User for large assemblys over 1GB.
I also havent found a command that directly exits the Express mode while the doc is opened without closing it.
Message 6 of 9
WCrihfield
Hi @fabian.steinruck.  Here are the two commands you are looking for:
AssemblyMakeHeavyWeightCmd
AssemblyMakeLightWeightCmd
...As you can imagine, the one with "MakeHeavy" will load the assembly fully, while the one with "MakeLight" will load it Express Mode.
Wesley Crihfield
(Not an Autodesk Employee)
Message 7 of 9
WCrihfield
Just in case you were not familiar with how to use those commands, they are the names of ControlDefinitions, which must be found, then executed, like this:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyMakeHeavyWeightCmd").Execute
The normal Inventor API way of switching an assembly from Express Mode to Load Full, is like this:
Dim oADoc As AssemblyDocument = ThisDoc.Document
If oADoc.IsOpenExpress Then
	oADoc.IsOpenExpress = False
That property can only be changed one way (from True to False, not from False to True).
Wesley Crihfield
Message 8 of 9
fabian.steinruck
Awesome!
Works as intended.
Such a time saver now!
Thank you
Message 9 of 9
fabian.steinruck
Also here is my complete Code with the implementation for exiting the Express mode
Maybe usefull for othere people
Spoiler
Imports System.Windows.Forms
Imports System.IO
Imports System.Diagnostics
Sub Main()
    Dim oDocument As Document = ThisApplication.ActiveDocument
    ' CHECK THAT PART OR ASSEMBLY FILE IS OPEN.
    If Not (oDocument.DocumentType = kAssemblyDocumentObject Or oDocument.DocumentType = kPartDocumentObject) Then
        MessageBox.Show("STEP können nur von 3D Modellen erzeugt werden", "Kein 3D Modell", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    ' GET THE FILE NAME FROM ACTIVE DOCUMENT.
    Dim oFileName As String = oDocument.DisplayName.Replace(".iam", "").Replace(".ipt", "")
    ' SET THE DEFAULT FOLDER PATH FOR FILE LOCATION.
    Dim sUserName As String = Environ("Username")
    Dim iPath As String = "C:\Users\" + sUserName + "\Documents\_Vault\"
    ' GET THE EXPORT FILE LOCATION FROM USER INPUT.
    Dim oFilePath = InputBox("Ordnerpfad angeben:" & vbNewLine & vbNewLine _
        & "Dateiname der STEP ist der Anzeigename der Baugruppe im Inventor Browser" _
        & vbNewLine & vbNewLine & "Vorschau:" & vbNewLine _
		& oFileName & ".stp" & vbNewLine & vbNewLine _
        & "Pfad kann mittels STRG+V eingefügt werden!", "Angabe STEP Ablageort", iPath)
    ' CHECK IF USER INPUT IS VALID
    If oFilePath = "" Then
        MessageBox.Show("Export Abgebrochen", "Export Abgebrochen", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    ' Exiting Express mode, only try if it's an assembly doc
    If oDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim oAssemblyDocument As AssemblyDocument = oDocument
        If oAssemblyDocument.ComponentDefinition.IsOpenExpress Then
            oAssemblyDocument.ComponentDefinition.IsOpenExpress = False
    ' Change "Ansichtsdarstellung" to Mainview
    Dim oCompDef As ComponentDefinition = oDocument.ComponentDefinition
    oCompDef.RepresentationsManager.DesignViewRepresentations.Item("Hauptansicht").Activate()
    ' GET THE STEP EXPORT ADDIN USING ID & ACTIVATE IT.
    Dim oInvAddIns As ApplicationAddIns = ThisApplication.ApplicationAddIns
    Dim STEP_TranslatorAddIn As TranslatorAddIn = oInvAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") 'TRANSLATOR: STP EXPORT
    STEP_TranslatorAddIn.Activate()
    Dim transientObj As TransientObjects = ThisApplication.TransientObjects
    Dim oContext As TranslationContext = transientObj.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOptions As NameValueMap = transientObj.CreateNameValueMap
    Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' CHECK IF THE TRANSLATOR HAS 'SAVECOPYAS' OPTIONS
    If STEP_TranslatorAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        oOptions.Value("ApplicationProtocolType") = 2 ' INTEGER
        oOptions.Value("IncludeSketches") = False ' BOOLEAN
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oDataMedium.FileName = oFilePath & "\" & oFileName & ".stp"
        ' EXPORT STEP WITH PRE-SELECTED SETTINGS IN THE SELECTED FILE LOCATION.
        Try
            STEP_TranslatorAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
            ' Fancy Success message box
            ' Dim message As String = "Export erfolgreich." & vbNewLine & vbNewLine _
            ' & "Pfad: " & vbNewLine & oFilePath & vbNewLine & vbNewLine & "Name: " & vbNewLine & oFileName & ".stp"
            ' MsgBox(message, vbInformation, "Export Erfolgreich")
        Catch
            MessageBox.Show("Bei der STEP Erzeugung scheint etwas schief gelaufen zu sein", "Fehler", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
    STEP_TranslatorAddIn.Deactivate()
End Sub
