Multiple Add-ins calling same Events
Majjek
Majjek
I've created an add-in which uses the OnSave event to do some stuff.
It all works fine, but our customer also has another add-in running, which also uses the OnSave event (3rd party).
This seems to give some troubles, as not everything works the same as on my local PC, where I only have my add-in running.
Does anyone know how Inventor handles these situations?
Thanks in advance.
bradeneuropeArthur
This is the default behavior.
two or more add in with the same event are always tricky.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Majjek
Thanks for the fast response Arthur.
So there is no way to determine in which order the add-ins are being handled.
bradeneuropeArthur
Sure that is possible, but than you need to reprogram your add in. (or your customer)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Majjek
Ok, thanks for the replies.
