I am making a complex illogic code... one thing that I want it to do it to add a colour to all view on the file.
for now it work on part(Ipt)...
It change colour on all the view .. my problem is that I want it that o go want to the view that you where working on before running the code... I have a other code that do this ... but it is for assembly only ..... so I can´t just copy past that part of the code....but it work for assembly ... that I will have to make my code later paint a colour as well
the code below create some standard view .. and go back to the view I work on ... how to I go back to the active view before I run the code on a part?
' get Manager of Representations
Dim dViewRepMgr As RepresentationsManager
dViewRepMgr = oAsmCompDef.RepresentationsManager
'Get active Representation View
Dim dViewRep As DesignViewRepresentation
dViewRep = dViewRepMgr.ActiveDesignViewRepresentation
'Dim AktivVeiw As String
'AktivVeiw = "Master"
'MessageBox.Show(AktivVeiw, "Info")
Try
'create a list of view reps
For Each oViewRep In oViewReps
NameList.Add(oViewRep.Name)
Next
'check names
'-----------------------------------Tilføje Asset view ----------------------
'If NameList.Contains("Asset") = False Then
''set View Rep active
'oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Asset")
'StandardViewCreate = True
'MessageBox.Show("Veiw Asset was created", "Info")
'End If
If NameList.Contains("Complete") = False Then
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Complete")
'MessageBox.Show("Veiw Complete was created", "Info")
If NameList.Contains("Simplified") = False Then
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Simplified")
'MessageBox.Show("Veiw Simplified was created", "Info")
If StandardViewCreate = True Then
'Return to orginal aktiv veiw
dViewRep.Activate
'Tilføj denne nedestående kode igen hvis man ønsker en beked om at de sandard views er blevet lavet
'MessageBox.Show("Standard veiws was created", "Info")
StandardViewCreate = False
Catch
End Try
Catch
End Try
