Move pdf files to new folder
anyone help out with some illogic that will move all pdf files from one folder to another?
Thanks in adavance
MechMachineMan
If you are writing in vb.net, I recommend you check out the MSDN website; ie google: "move files + MSDN + vb.net".
You might also have luck just googling it without the MSDN as stackoverflow often has a ton of good information.
I've written functions that do this before so it's definitely easily possible.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
thanks Justin, I've invested 2+ hours in google searches already prior to posting. I have a workaround in place (not as pretty) but will invest another hour or two over the weekend.
cheers!
MechMachineMan
http://lmgtfy.com/?q=mdsn+%2B+vb.net+%2B+move+files&l=1
As you see here, it provides the File.Move method.
In order to use this, you either need to:
                a) add "Imports System.IO" to the top of your program OR
                b) call it as: System.IO.File.Move(sourcefilename, desitnationfilename).
That tough. Shouldn't have taken 2 hours (took me <50 seconds). Hopefully this will save you some time next time you need to look things up!
Justin K
Hope this Vba code might helpful for you to move the pdf files to another folder
Sub Move_Pdf_Files()
'This example move the Pdf Files from FromPath to ToPath.
    Dim FSO As Object
    Dim FromPath As String
    Dim ToPath As String
    Dim FileType As String
        FromPath = "F:\New folder\test"  '<< Change
        ToPath = "F:\New folder\test1"    '<< Change
        If Right(FromPath, 1) = "\" Then
            FromPath = Left(FromPath, Len(FromPath) - 1)
        If Right(ToPath, 1) = "\" Then
            ToPath = Left(ToPath, Len(ToPath) - 1)
        Set FSO = CreateObject("scripting.filesystemobject")
        If FSO.FolderExists(FromPath) = False Then
            MsgBox FromPath & " doesn't exist Please create the folder First"
            Exit Sub
        Set Folder = FSO.GetFolder(FromPath)
        For Each Filename In Folder.Files
            FileType = Right(Filename, 3)
            If FileType = "pdf" Then
                oFilename = FSO.GetFileName(Filename)
                ToFileName = ToPath & "\" & oFilename
                FileCopy Filename, ToFileName
                Filename.Delete
        Next
End Sub
