Adding a custom property call parent.
Message 1 of 8
Is there an iLogic rule that can make a custom property call parent (in every component in an assembly) and automatically fill it out with the parents file name? I would like to run a rule at the top level and drive in the information automatically.
For example:
Assembly file name – 1260-01
Subassembly file name – 1260-S20
All parts in the top level including the subassembly will add a custom property call parent and filled out with 1260-01.
All the parts in the subassembly will add a custom property call parent and filled out with 1260-S20.
That would help out a lot if anyone could help. It will cause a few problem that I will still need to work out. In the case if a part is in the assembly and subassembly then the custom property call parent, the field would have to have two different names filed in. If anyone has any ideas on how to get around that it would be awesome. If you could only help with one or the other that would be great.
Replies (7)
Message 2 of 8
MechMachineMan
Just have it fill in a Parent line for each file that is referenced.
You may have fun keeping the parent property up to date if the part is used in a different assembly though, or if the part gets removed/moved/replaced, so you will have to develop some sort of scheme for keeping it up to date.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 8
wayne.brill
Here is an example I created. I believe it does something like you are asking for.
Sub Main
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
	'Iterate through all of the occurrences
	Dim oOccurrence As ComponentOccurrence
	For Each oOccurrence In oAsmCompDef.Occurrences
		Call ProcessAllChildren(oOccurrence)
	Next
End Sub
Public Sub ProcessAllChildren(ByRef oOccurrence As ComponentOccurrence)
		' Get the custom property set.
    	Dim invCustomPropertySet As PropertySet
    	invCustomPropertySet = oOccurrence.Definition.Document.PropertySets.Item("Inventor User Defined Properties")
		Dim invParentCustProp As Inventor.Property
		Try
			'If this fails Parent_Name Property does not exist
			invParentCustProp = invCustomPropertySet.Item("Parent_Name")
			'MessageBox.Show("invParentCustProp Exists" , oOccurrence.Name)
       	Catch
			' Create the property as it did not exist.
			'MessageBox.Show("invParentCustProp Does not Exist" , oOccurrence.Name)
			Try
				' oOccurrence.ParentOccurrence is nothing if it is a top level occurrence
				' ParentOccurence will be the sub assembly the occurrence is in
				invCustomPropertySet.Add(oOccurrence.ParentOccurrence.Definition.Document.DisplayName, "Parent_Name")
			Catch
				'This works if the occurrence is in the top level assembly
				' oOccurrence.Parent.Document.DisplayName
				invCustomPropertySet.Add(oOccurrence.Parent.Document.DisplayName, "Parent_Name")
			End Try
		End Try
		'Update the value for the custom property for this occurrence if it does not already have it
		Try
			Dim strExistingVal As String = invParentCustProp.Value
			If Not strExistingVal.Contains(oOccurrence.ParentOccurrence.Definition.Document.DisplayName) Then
			' Try to get the ParentOccurrence, this will fail if it is a top level occurrence
			invParentCustProp.Value = strExistingVal & " ; " & oOccurrence.ParentOccurrence.Definition.Document.DisplayName
			'MessageBox.Show("In Try after Occurrence.ParentOccurrence.Definition.Document.DisplayName" , oOccurrence.ParentOccurrence.Definition.Document.DisplayName)
		Catch
			If Not strExistingVal.Contains(oOccurrence.Parent.Document.DisplayName) Then
			'This works the top level assembly
			invParentCustProp.Value =  strExistingVal & " ; " & oOccurrence.Parent.Document.DisplayName
		End Try
	Dim oCompOcc As ComponentOccurrence
	Dim oComponentSubOccurrences As ComponentOccurrences
    For Each oCompOcc In oOccurrence.SubOccurrences
        If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
           oComponentSubOccurrences = oCompOcc.SubOccurrences
		   If Not oComponentSubOccurrences Is Nothing Then
			If oComponentSubOccurrences.count > 0 Then
				ProcessAllChildren(oCompOcc)
        Else
     Next
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 4 of 8
Thank you so much for your help. That does exactly what I needed it to do. Is there an easy way to get rid of the .jam in the description?  Thank you again this will be very helpful.
Message 5 of 8
ekinsb
I'm glad Wayne's program is working for you.  He's on a well deserved vacation now so I thought I would follow-up with this.  I don't understand what you mean by getting rid of the .jam in the description.  I don't see anything like that.
Brian Ekins
Mod the Machine blog
Message 6 of 8
When it fills in the custom property “Parent_Name” the ext. is part of the description. I was just wounding if there is a way that when looking at the parent file name that it could leave the ext. off. Thanks for any help you could give.
Message 7 of 8
ekinsb
Here's a modified version of Wayne's rule that doesn't write out the file extension.
Sub Main
	Next
End Sub
    	invCustomPropertySet = oOccurrence.Definition.Document.PropertySets.Item(​"Inventor User Defined Properties")
		Try
       	Catch
			Try
				Dim filename As String = System.IO.Path.GetFileNameWithoutExtension(oOccurrence.parentOccurrence.Definition.Document.Displayname)
				invCustomPropertySet.Add(filename, "Parent_Name")
			Catch
				Dim filename As String = System.IO.Path.GetFileNameWithoutExtension(oOccurrence.Parent.Document.DisplayName)
			End Try
		End Try
		Try
			Dim filename As String = System.IO.Path.GetFileNameWithoutExtension(oOccurrence.ParentOccurrence.Definition.Document.DisplayName)
			If Not strExistingVal.Contains(filename) Then
				invParentCustProp.Value = strExistingVal & " ; " & filename
				'MessageBox.Show("In Try after Occurrence.ParentOccurrence.Definition.Document.Di​splayName" , oOccurrence.ParentOccurrence.Definition.Document.D​isplayName)
		Catch
		End Try
        Else
     Next
End Sub
Brian Ekins
Message 8 of 8
Thank you very much for your help. That is exactly what I needed.
