Modifying Assembly Model States
dustinbagley
Message 1 of 9
dustinbagley
I have an assembly with 2 model states. The first will be dynamically controlled through iLogic. The second will be static. Despite a few different attempts. I cannot make changes to the first without affecting the second. In my rule, I first include a statement to set the model state as well as setting the member edit scope:
Dim oModelState As ModelState
ThisAssembly.Document.ComponentDefinition.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
For Each oModelState In ThisAssembly.Document.ComponentDefinition.ModelStates
	If oModelState.Name = "[Primary]" Then
		oModelState.Activate()
	End If
Next
 Next, for my dynamic model state, I set the suppression of each part with this type of thing:
If somthing = something Then
Component
.IsActive("...") = False
Else
Component.IsActive("...") = True
End If
 Next, for the static model state, I switch model states as follows:
	If oModelState.Name = "Posts" Then
	End If
Next
And finally, set the suppression state of the appropriate parts in a similar way as seen above.
The rule runs as though kEditAllMembers is set. Is there something I'm missing? Thanks
Replies (8)
Message 2 of 9
WCrihfield
Hi @dustinbagley.  Where you are using 'ThisAssembly.Document', try using 'ThisDoc.FactoryDocument' instead.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 9
dustinbagley
Thanks for responding. I replaced
with
ThisDoc.FactoryDocument.ComponentDefinition.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
and I am still getting the same results.
I also tried making the same change you recommended in the state switching statements:
	End If
Next
 but intelesense did not have it available so I left those unchanged.
Message 4 of 9
Curtis_Waguespack
Hi @dustinbagley
If I understand correctly, you're looking for something like this.
I hope this helps.
Curtis
  • This gets user input as a true/false value for testing
  • sets the edit scope to member
  • sets the primary model state to be active
  • sets suppression of 2 components based on the user input
  • sets the posts model state to be active
  • sets the primary model state to be active, again.
something = InputRadioBox("something?", "True", "False", True, "iLogic")
Dim oMStates As ModelStates
oMStates = ThisAssembly.Document.ComponentDefinition.ModelStates
oMStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
'set primary active
oMStates.Item(1).Activate 'primary
If something = True Then
	Component.IsActive("Comp1") = True
	Component.IsActive("Comp2") = True
Else
	Component.IsActive("Comp1") = False
	Component.IsActive("Comp2") = False
End If
MsgBox("Pause to examine browser" ,,   ThisAssembly.Document.ModelStateName)
'set posts MS active
oMStates.Item("Posts").Activate
Else
End If
'set primary active again
Message 5 of 9
dustinbagley
Yes that's right, my issue however is that, despite setting kActiveMember and despite making suppression modifications only after changing model states, both model states are affected by the changes.
Message 6 of 9
Curtis_Waguespack
Hi @dustinbagley
@dustinbagley wrote:
... despite making suppression modifications only after changing model states, both model states are affected by the changes.
I am not seeing that result with the example I posted.
    edit: attached is a simple assembly (MS_test.iam) that you can test this on.
Can you confirm that you are seeing unexpected results with this example?
Message 7 of 9
WCrihfield
The Intellisense may not show that the properties are available, but the code should still work the way I suggested.  I generally tend to not use really long lines of code repetitively though.  I like to get important objects like the document and ModelStates collection set to a variable that I can reuse, instead of repeating the long line of code to get to that point.  That little change just ensures that you are working with the 'Factory' version of the document, which is the only version that is Read/Write, instead of a 'member' document, which is usually ReadOnly.  This is usually not quite as important when working directly with that document, when it is the active document on your screen though.  Below is just another example similar to yours, but with a couple things changed.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oADoc As AssemblyDocument = ThisDoc.FactoryDocument
Dim oMSs As ModelStates = oADoc.ComponentDefinition.ModelStates
'first ModelState (ModelStates.Item(1)) is always Master or Primary
oMSs.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
OriginallyActiveModelState = oMSs.ActiveModelState 'record for later, to restore
oMSs.Item(1).Activate 'activate Primary ModelState
'If something = somethingelse Then
'	oADoc.ComponentDefinition.Occurrences.ItemByName("...").Suppress(True) 'same as IsActive = False
'	Component.IsActive("...") = False
'Else
'	oADoc.ComponentDefinition.Occurrences.ItemByName("...").Unsuppress 'same as IsActive = True
'	Component.IsActive("...") = True
'End If
oMSs.Item("Posts").Activate
OriginallyActiveModelState.Activate
Oops...a little late with this responce.
Wesley Crihfield
Message 8 of 9
WCrihfield
This is just a hunch, because I honestly do not use the Component.IsActive() that much anymore, especially now that I have to deal with ModelStates, so I have another thought.  Maybe that iLogic snippet is not good to use while going through multiple ModelStates and activating them, because it doesn't handle the document references correctly.  Maybe you need to be capturing the document each time after you have activated a different ModelState, because activating a ModelState changes the active document reference.  Maybe something like this would work a little better.
Dim oMSDoc As AssemblyDocument = Nothing
Dim oOccs As ComponentOccurrences = Nothing
oMSDoc = oMSs.Item(1).FactoryDocument
oOccs = oMSDoc.ComponentDefinition.Occurrences
'	oOccs.ItemByName("...").Suppress(True) 'same as IsActive = False
'Else
'	oOccs.ItemByName("...").Unsuppress 'same as IsActive = True
'End If
oMSDoc = oMSs.Item("Posts").FactoryDocument
'Else
'End If
Or maybe we could use the StandardObjectProvider / StandardObjectFactory route, while using the ModelState.Document or ModelState.FactoryDocument object as input, so that the Component.IsActive will be referencing the correct document.
SOP = StandardObjectFactory.Create(oMSs.Item("Posts").Document)
SOP.Component.IsActive("...") = True
Wesley Crihfield
Message 9 of 9
dustinbagley
Thanks for you help, I've got it working now.
