Conditional text formatting
vvvxxvvv333
Message 1 of 12
vvvxxvvv333
There is a custom iProrety "Db" which has two values "Painted" or "Furner" In the drawing, I add a text that displays this value. With this expression
FormattedText= "<Property Document='model' PropertySet='User Defined Properties' Property='Db' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='28'>Db</Property>"
If you change the value in the part, the text in the drawing changes automatically. And it's convenient.
But I need the text to be formatted according to the condition, if the value = “Painted” the text should be italic and if = “Furner” bold
What should I change to make this happen automatically?
Accepted solutions (3)
Replies (11)
Message 2 of 12
Curtis_W
Hi @vvvxxvvv333
Thanks for providing the example files!
See examples below.
I hope this helps.
Curtis
See this rule for the conditional formatting:
oSheet = ThisDoc.Document.Sheets(1)
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oProperty = ThisDoc.ModelDocument.PropertySets.Item(4).Item("Db").Value
If UCase(oProperty) = "PAINTED" Then
	sText = "<StyleOverride Italic='True'><Property Document='model' " & _
	"PropertySet='User Defined Properties' Property='Db' " & _
	"FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='3'>Db</Property></StyleOverride>"
Else
	sText = "<StyleOverride Bold='True'><Property Document='model' " & _
	"PropertySet ='User Defined Properties' Property='Db' " & _
Dim oNote As GeneralNote
Dim oGenNotes = oSheet.DrawingNotes.GeneralNotes
For Each oNote In oSheet.DrawingNotes.GeneralNotes
	If UCase(oNote.Text) = "PAINTED" Or UCase(oNote.Text) = ("FURNER") Then oNote.Delete
Next
oGenNotes.AddFitted(oTG.CreatePoint2d(30, 5), sText)
 And you can use this simple 'helper' rule to get the formatting:
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oNotes As GeneralNotes = oSheet.DrawingNotes.GeneralNotes
For Each oNote In oNotes
	'get formatted text
	InputBox("This is the formatted text for Textbox" & i, "ilogic", oNote.FormattedText)
	i = i + 1
Next
Message 3 of 12
vvvxxvvv333
Thanks a lot for your reply and trying to help. But your rule defines what the font should be when placed, depending on the condition, but it does not change automatically if you change the parameter in the part
Message 4 of 12
robertast
The idea is very good. @johnsonshiue  @CGBenner     Could you ask the team if this can be done in Inventor?
Message 5 of 12
CGBenner
@robertast
You can share your idea HERE, and ask the Community to vote for it if they agree.  Thanks!
Chris Benner
Message 6 of 12
robertast
the question was to ask the team if this can be done in 2023.3 or if there is no such possibility at all
Message 7 of 12
Curtis_W
Hi @robertast
There is no update in this behavior in Inventor Inventor 2023 compared to Inventor 2022 or previous.
I hope this helps.
Curtis
Message 8 of 12
Curtis_W
Hi @vvvxxvvv333
To get the drawing to update automatically when the model property is updated you could do something like what is shown below.
I hope this helps.
Curtis
1. Update the rule in the part model:
iProperties.Value("Custom", "Db") = Ds
iLogicVb.UpdateWhenDone = True
oDrawDoc = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), True)
Dim DrawingUserParams As UserParameters
DrawingUserParams = oDrawDoc.Parameters.UserParameters
DrawingUserParams.Item("Parmeter_Db").Value = Ds
Thisdoc.Document.Activate
2. add a parameter to the drawing:
3. Update the drawing rule:
oTrigger = Parmeter_Db
Else
Next
Message 9 of 12
Curtis_W
@vvvxxvvv333
Another approach would be to delete the drawing rule and just have all of the code in the part model rule:
Dim oDrawDoc As DrawingDocument = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), True)
oSheet = oDrawDoc.Sheets.Item(1)
Dim oProperty = ThisDoc.Document.PropertySets.Item(4).Item("Db").Value
Else
Next
Message 10 of 12
vvvxxvvv333
You are a wizard 👍👍👍
Maybe ShowTextBorder can also be applied this way?
I also thought about putting all the formatting text into one more parameter. But I didn't figure out how to use it.
If Ds= Painted  Then
  iProperties.Value("Custom", "Dg") ="<StyleOverride Italic='True'><Property Document='model' " & _
Else
  iProperties.Value("Custom", "Dg") ="<StyleOverride Bold='True'><Property Document='model' " & _
Message 11 of 12
robertast
There is another option through the trigger.
Message 12 of 12
robertast
You can also try with "Rule Format"
Dim invApp As Inventor.Application
    invApp = ThisApplication
    Dim oDrawDoc As Document
    oDrawDoc = invApp.ActiveEditDocument
    oSheet = ActiveSheet.Sheet
	Dim oGeneralNote As GeneralNote
        For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes
           oGeneralNote.ToString
	Dim oText As String
    	oText = oGeneralNote.Text
		 If oText = "Furner" Then
			 	Dim oFormattedText As String
    			oFormattedText = "<StyleOverride Bold='True'>" & oText & "</StyleOverride>"
	 			oGeneralNote.FormattedText = oFormattedText
				Else
    			oFormattedText = "<StyleOverride Italic='True'>" & oText & "</StyleOverride>"
    	oGeneralNote .HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
        Next
