- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
we will be updating Inventor 2021 to 2023 and I have noticed that existing VBA macros no longer work.
After many small tests I could find that the macros do not work if a second model state exists.
Is such a problem known? Can anyone confirm this?
As an example I have prepared a small macro:
Public Sub Test()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
Set oOcc = oDoc.ComponentDefinition.Occurrences.Item(1)
Dim oParameters As Parameters
Set oParameters = oOcc.Definition.Parameters
oParameters.Item("Breite").value = 20
End Sub
You need an assembly for it. In this assembly comes a part. And this part needs 2 model states and a parameter called "Breite". Run the macro in the assembly.
The error then appears when setting the parameter value.
If you remove the second model state, the macro works.
Regards
Michael
