Migrating the plugin for Inventor 2023 to Inventor 2026
pavol_krasnansky1
pavol_krasnansky1
Hi, I migrated from Inventor 2023 to Inventor 2026. I have a plugin for opening drawings. The plugin works in Inventor 2023. It works in Inventor 2026 when the model/drawing is saved in Inventor 2023. It does not work in Inventor 2026 when the model/drawing is saved in Inventor 2026. What do I need to change to make it work? The plugin is attached.
bradeneuropeArthur
Hello @pavol_krasnansky1
  1. this is not not a add in
  2. the reference to the Autodesk Inventor is made by a newer version than the drawing created with.
  3. Using apprentice server.
Solution:
  1. Create a real add-in to avoid problems with version of the Inventor Application
  2. Install apprentice server separately maybe you forgot to install
    https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7E5yOOlf0n3RxRfXa3F1to.html
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
