Max point of section line
BrandonBG
Message 1 of 15
BrandonBG
How do identify the SketchLine that cuts the section and get the max point through the API?
My current route is:
Identify a SectionDrawingView
Find the Parent of the SectionDrawingView: a DrawingView
Find the SectionLineSketch from the DrawingView
The SectionLineSketch object contains the SketchLine that defines the section, but it also contains any projected SketchLine used to constrain the section line in SketchLines. I can't tell which line is the section line and which is a projected line. At first, I assumed SketchLines.Item(1) was the section line, but this is not the case.
Why am I doing this? I'm making a custom section line label, and because the API does not have an object for the label on the parent view, I have to hide the existing and drop a sketched symbol on the end point of the section line.
Which SketchLine defines the view?
Brandon
Inventor 2016
Replies (14)
Message 2 of 15
MechMachineMan
I just did this. It's annoying AF. Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 15
MechMachineMan
Here. I'll make your day. Exactly as mine is. It's a little more complicated; we use 2 symbols just because the orientation of the text changes with respect to the arrows for 2 cases, but it'll get you most of the way there
'SECTION SYMBOL WIZARD
'JRK - 30.Jun.15
'PURPOSE - By running this rule, it allows you to place section symbols and tweak them for each drawing view in the sheet
'v0 - RELEASE
Sub Main()
'Variable Declarations
Dim oDwgDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
Dim oDLine As DrawingCurveSegment
Dim oView As DrawingView
Dim oSketch As DrawingSketch
Dim oLine As SketchLine
Dim oSecLine As SketchLine
Dim oSecEP As Point2d
Dim oSecSP As Point2d
Dim angle As Double
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oGeometryIntent1 As GeometryIntent
Dim oLeaderPoints1 As ObjectCollection
Dim oGeometryIntent2 As GeometryIntent
Dim oLeaderPoints2 As ObjectCollection
Dim oSSD As SketchedSymbolDefinition
Dim oSSD1 As SketchedSymbolDefinition
Dim oSSD2 As SketchedSymbolDefinition
Dim oSSD3 As SketchedSymbolDefinition
Dim oControlDef1 As ControlDefinition
Dim oTextBoxes As TextBoxes
Dim FS As Boolean = True
Dim RS As Boolean = True
'''Begin functionality
oDLine = oCommandMgr.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select the LINE")
oSP = oDLine.StartPoint
oEP = oDLine.EndPoint
Dim oV1 As Vector2d
Dim oV2 As Vector2d
If oEP.Y > oSP.Y
	oV1 = ThisApplication.TransientGeometry.CreateVector2d(oEP.X - oSP.X, oEP.Y - oSP.Y)
	oV2 = ThisApplication.TransientGeometry.CreateVector2d(1, 0)
Else
	oV1 = ThisApplication.TransientGeometry.CreateVector2d(oSP.X - oEP.X, oSP.Y - oEP.Y)
angle = oV2.AngleTo(oV1)
For Each oView In oDwgDoc.ActiveSheet.DrawingViews
	For Each oSketch In oView.Sketches
		For Each oLine In oSketch.SketchLines
			If Math.Abs(Math.Round(oView.Scale*(oLine.StartSketchPoint.Geometry.X - oLine.EndSketchPoint.Geometry.X),3)) = Math.Abs(Math.Round((oSP.X - oEP.X),3)) And _
				Math.Abs(Math.Round(oView.Scale*(oLine.StartSketchPoint.Geometry.Y - oLine.EndSketchPoint.Geometry.Y),3)) = Math.Abs(Math.Round((oSP.Y - oEP.Y),3))
				oSecLine = oLine
				oCP = oTG.CreatePoint2d(oSketch.Parent.Position.X, oSketch.Parent.Position.Y)
				oSecSP = oTG.CreatePoint2d(oCP.X +oSecLine.StartSketchPoint.Geometry.X*oView.Scale, oCP.Y + oSecLine.StartSketchPoint.Geometry.Y*oView.Scale)
				oSecEP = oTG.CreatePoint2d(oCP.X +oSecLine.EndSketchPoint.Geometry.X*oView.Scale, oCP.Y + oSecLine.EndSketchPoint.Geometry.Y*oView.Scale)
		Next
	Next
Next
oLeaderPoints1 = ThisApplication.TransientObjects.CreateObjectCollection
'oLeaderPoints1.Add(oSP)
'oLeaderPoints1.Add(oSecSP)
oGeometryIntent1 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecSP)
oLeaderPoints1.Add(oGeometryIntent1)
oLeaderPoints2 = ThisApplication.TransientObjects.CreateObjectCollection
'oLeaderPoints2.Add(oEP)
'oLeaderPoints2.Add(oSecEP)
oGeometryIntent2 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecEP)
oLeaderPoints2.Add(oGeometryIntent2)
Dim PromptStrings(0 To 1) As String
PromptStrings(0) = ""
PromptStrings(1) = ""
oSSD1 = oDwgDoc.SketchedSymbolDefinitions.Item("Section Tail")
oSSD2 = oDwgDoc.SketchedSymbolDefinitions.Item("Section Symbol - Up")
oSSD3 = oDwgDoc.SketchedSymbolDefinitions.Item("Section Symbol - Down")
angle = NormalizeAngle(angle + Math.PI)
'Decide which sketched symbol to use based upon angle
If (0 <= angle And angle < (Math.PI/2)) Or (3*Math.PI/2) <= angle And angle < (2*Math.PI)
	oSSD = oSSD2
	angle1 = angle
Else
	oSSD = oSSD3
	angle1 = NormalizeAngle(angle + Math.PI)
oS1 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD1,oLeaderPoints1,angle,1,,False,True)
	oS1.LeaderVisible = False
oS2 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD,oLeaderPoints2,angle1,1,PromptStrings,False,True)
	oS2.LeaderVisible = False
oSelectSet = oDwgDoc.SelectSet
   	oSelectSet.Clear
	oSelectSet.Select(oS2)
oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingEditFieldTextCmd")
oControlDef1.Execute
oTextBoxes = oS2.Definition.Sketch.TextBoxes
PromptStrings(0) = oS2.GetResultText(oTextBoxes.Item(1))
PromptStrings(1) = oS2.GetResultText(oTextBoxes.Item(2))
While FS = True And RS = True
	'Reset
	FS = True
	RS = True
	'Rotate Symbol
	oRS = MsgBox("Rotate Symbols 180 degrees?", MsgBoxStyle.YesNo, "Section Symbols")
		If oRS = vbNo
			RS = False
		Else
			oS1.Delete
			oS2.Delete
				oSSD = oSSD2
			Else
				oSSD = oSSD3
	'Swap Symbols
	oFS = MsgBox("Swap Head and Tail?", MsgBoxStyle.YesNo, "Section Symbols")
		If oFS = vbNo
			FS = False
		Else
			oS1.Delete
			oS2.Delete
			oS1 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD1,oLeaderPoints2,angle,1,,False,True)
			oS2 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD,oLeaderPoints1,angle1,1,PromptStrings,False,True)
End While 'Fs / RS = True
oRemoveLabels
End Sub
Function NormalizeAngle(angle As Double)
Dim oAngle As Double
Dim multiple As Integer
If Math.Abs(angle) >= 2*Math.PI
	multiple = angle \ 2*Math.PI
	oAngle = angle - multiple*2*Math.PI
Else
	oAngle = angle
Return oAngle
End Function
Sub oRemoveLabels
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim i As String = ""
For Each oView In oDoc.ActiveSheet.DrawingViews
	If oView.Type = ObjectTypeEnum.kSectionDrawingViewObject
		oView.ShowLabel = False
		i = " " + i
		oView.Name = i
Next
End Sub
Justin K
Message 4 of 15
MechMachineMan
Anyone reading this please go upvote this:
http://forums.autodesk.com/t5/inventor-ideastation/batch-of-ideas-api-assembly-modelling/idi-p/57227...
Justin K
Message 5 of 15
MechMachineMan
Also, notes for tweaking the code I posted:
-More leader points would need to be added if you dont want the symbols sitting on the endpoints of the section line.
-The sketch of the section line is scaled as per the view scale, so to translate those coordinates, you need to use the centre for the view as well as the view scale.
-The symbol I use with mine only has 2 fields of prompted text in it and some sketch lines, which will need tweaking if you use anything different.
Justin K
Message 6 of 15
BrandonBG
Excellent work, sir! I find the lack of access to the section label baffling.
And I guess I wasn't crazy when I had 193 lines of code and no solution.
The key for me was getting the scale multiplier mixed in with the center of the parent view.
I'm going to work with your code and mine and see if can get this fully automated. I'm comparing camera angles to determine which way the section view points relative to the base view.
Any ideas on how to get to that section line without have to pick it?
Brandon
Message 7 of 15
MechMachineMan
Just by using the section views you could probably reference back to the sketch. However, I included the selection so it could easily be done after the fact or for old drawings; too much automation can be a bad thing sometimes. Especially in big chunks.
Justin K
Message 8 of 15
BrandonBG
I think I cracked it.
I compare the SketchLines inside the Sketch of the section line.
oSketchLine.Reference = False for the section line, while everything else is True. Again, this works in my situation where I only use staight, single line section lines.
For Each oSketchLine In oSectionLine.Sketchlines
	If oSketchLine.Reference = False Then
		oPosition = oSketchLine.RangeBox.MaxPoint
Next
Brandon
Message 9 of 15
MechMachineMan
Hey Brandon, did you even figure out a good way to find out which way the section view is pointing?
Justin K
Message 10 of 15
MechMachineMan
Eh, never mind. I saw you posted about using the camera in another post. So I tried using enums, but i didn't like that.
So instead I compared the up vector of the parent view to the page normal vector of the section view in order to figure out the angle of the parent view that the section comes off at. With this, I'll then be able to automatically set the view angle for any view 🙂
Thanks for the nudge!
Justin K
Message 11 of 15
BrandonBG
Are you able to get 90-180-270 degree angles comparing up vectors? This may be an avenue for me to explore.
I kind of gave up on the camera because I'd get weird 89.996348 angles using the projected views, and made a toggle button that rotates the section arrow 180 degrees back in forth when it points the wrong way.
Brandon
Message 12 of 15
MechMachineMan
Yup!
Mostly just happy all those math classes I had to take to get my degree finally paid off Smiley LOL
Essentially, what it does, is it gets the vectors of the views from the eye to target (ie; into the page) for the parent and section.
Then it uses the upvector of the parent view. From there it checks via comparing the cross product of the UpVector and SectionViewVector to the IntoPageParentViewVector.
Based if they are the same or not, I know which orientation the angle is starting from.
From there, I just get the angle between the section vector and the up vector and return that.
'JRK - SectionViewAngleCalc
'Winter 2016
'Purpose: Get the angle of a section view with respect to the UpVector of the parent view.
Sub Main() Dim oCmdMgr As CommandManager = ThisApplication.CommandManager oView = oCmdMgr.Pick(SelectionFilterEnum.kDrawingViewFilter,"Pick Drawing View") oParentView = oView.ParentView Dim oSecVector, oParentVector, CrossVector As Vector oSecVector = GetViewVector(oView) oParentVector = GetViewVector(oParentView) oParentUpVector = oParentView.Camera.UpVector.AsVector oCrossVector = oParentUpVector.CrossProduct(oSecVector) Dim oRot As Double oRot = NormalizeAngle(oParentUpVector.AngleTo(oSecVector), True) If oSecVector.IsParallelTo(oParentUpVector) And oRot = 180 oAngle = 0 Else If oSecVector.IsParallelTo(oParentUpVector) And oRot = 0 oAngle = 180 Else oCrossVector.Normalize oParentVector.Normalize If oCrossVector.IsEqualTo(oParentVector, .005) oAngle = oRot + 180 Else oAngle = oRot End If End If MsgBox("Degress From UpVector To Section View " & vbLf & _ "(Also Same as angle to rotate Up Symbol" & vbLf & vbLf & _ oAngle & "°") End Sub Function GetViewVector(oView As DrawingView) As Vector Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim oCam As Camera oCam = oView.Camera Dim oCamEye, oCamTarget As Point oCamEye = oCam.Eye oCamTarget = oCam.Target Dim oViewVector As Vector oViewVector = oTG.CreateVector(oCamEye.X - oCamTarget.X, oCamEye.Y - oCamTarget.Y, oCamEye.Z - oCamTarget.Z) 'oViewVector = oTG.CreateVector(oCamEye.X, oCamEye.Y, oCamEye.Z) Return oViewVector End Function Function NormalizeAngle(angle As Double, ReturnDegrees As Boolean) Dim oAngle As Double Dim multiple As Double If Math.Abs(angle) >= 2*Math.PI multiple = angle \ (2*Math.PI) oAngle = angle - multiple*2*Math.PI Else oAngle = angle End If If ReturnDegrees = False Return oAngle Else Return (180/Math.PI) * oAngle End If End Function
Justin K
Message 13 of 15
is there anyway you can delete the arrow (or show none) and delete text with this to?
Message 14 of 15
MechMachineMan
Using the section line styles you should be able to accomplish this.
Justin K
Message 15 of 15
what about deleting the text on some sections?
