Access iProperties of ActiveDocument
Message 1 of 12
I am trying to write an iLogic rule that when I have one file open it will open a second file I specify and grab some of its iProperties.  I can find and open the file just fine, but I am having trouble finding a way to access its iProperties.  I have been researching and I saw this article:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8CAEA21E-A604-4D0A-8F06-3FA5B693CE6B
Which looked to me like I could specify the second file's fileName and get its iProperties, but that doesn't seem to work.  I keep getting a null / blank value.  I then thought I could specify the active document and do something like:
SyntaxEditor Code Snippet
doc.PropertySets.Item("Project").Item("Description").Value
But that didn't work either.  Does anyone know how to access the iProperties of one document from another?
I'm stumped.
Replies (11)
Message 2 of 12
MechMachineMan
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 12
MechMachineMan
In the call that you use to open the 2nd document, make it something like
oDoc2 = ThisApplication.Documents.Open(...)
Then you can use oDoc2 to access that document you opened.
Justin K
Message 4 of 12
Owner2229
I'm using this one, as you can get the iProperties without opening the file:
Dim sTS As String = oDoc.FullFileName 'or just "C:/File.ipt"
Dim FNamePos As Long = InStrRev(sTS, "\", - 1)
Dim docFName As String = Mid(sTS, FNamePos + 1, Len(sTS) - FNamePos)
Dim Val1 As String = iProperties.Value(docFName, "Project", "Part Number")
On the other side, if I try to use this one, I'm getting blank parametes:
Dim Val1 As String = iProperties.Value(oDoc, "Project", "Part Number")
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 5 of 12
MechMachineMan
Umm. You can't fetch iProperties unless the document is open (albeit it may
be invisibly) or you are using AppreticeServer to access them.
Justin K
Message 6 of 12
Owner2229
Yay, my fault, I'm running it from assembly, so in my case the document truly is open.
Sorry for disinformation.
Mike
Message 7 of 12
So I've tried both of those, but everything is returning a null.
To test it out my code opens the file, then I attempt the two methods by trying to pull the revision number and diplaying it in a messagebox:
'...open dialog box, user selects a file "strFile"
Dim assemDoc As DrawingDocument
assemDoc = ThisApplication.Documents.Open(strFile)
Dim myProp As String
myProp = iProperties.Value(IO.Path.GetFileName(strFile),"Project", "Revision Number")
'Below MsgBox results in  "Method 1: '' "
MessageBox.Show("Method 1: "+ myProp , "Testing")
'Then I try specifying the filename explicitly just to be sure there isn't something dumb with using the GetFileName function above, but same results
myProp = iProperties.Value("X8053D27.idw","Project", "Revision Number")
MessageBox.Show("Method 2: "+ myProp, "Testing")
'Here is method 2 being tried, same result as before.
myProp = oIPT.PropertySets.Item("Project").Item("Revision Number").Value
MessageBox.Show("Method 3: "+ myProp , "Testing")
All of these methods end up resulting in an empty string being returned when I know that the revision on that file is Rev "A"
Message 8 of 12
MechMachineMan
You mean to say that your IDW's Sheet Revision Number is not being pulled in by the call to the iProperties?
There is a difference in the 2 fields. The revision that shows up in this window (and in revision tables; "Sheet Revision Number", and not an iProperty) vs the iProperty "Revision Number".
Justin K
Message 9 of 12
I'm trying to get the iProperty:
Message 10 of 12
MechMachineMan
Did you leave out lines of code, or is that your whole rule?
Justin K
Message 11 of 12
MechMachineMan
You have the wrong PropertySet being accessed;
MsgBox(ThisApplication.ActiveDocument.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value)
Justin K
Message 12 of 12
That was it exactly!  Thank you so much!
