Make Occurrence Set Visible As ?Transient Graphics?
MechMachineMan
Advisor Advisor
Message 1 of 1
MechMachineMan
Hi!
Looking for some guidance in trying to make a transient graphics set (I think).
What I want to do is create a macro that will show all of the occurrences I pass it as transient graphics similiar to that of the Analyze interference tool. I want to be able to view these parts through all other parts so that the end user can quickly use the model to view where the various components are located and how the might have changed. If it's possible I want to be able to save this in the current session so I can perform section views and such to view the parts.
Any help is much appreciated. Thanks!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Replies (0)
