Benefit of External Rules and Global Forms?
jfenter
jfenter
I'm still fairly new at using iLogic and wonder what the benefit of global rules and forms are over being locally-stored.  I am working on creating part templates and thought that using a global form would allow me to make changes in the future to all parts created from that template if a global rule/form was used.  Am I correct in that thinking?
I have also found that attempting to make changes to iProperties via external rules does not work.  For example, I have an external rule written to change the material type as:
SyntaxEditor Code Snippet
If Parameter("material") = "MS" Then
iProperties.Material= "MS"
ElseIf Parameter("material") = "FB" Then
iProperties.Material= "FB"
ElseIf Parameter("material") = "SS" Then
iProperties.Material="SS"
ElseIf Parameter("material") = "SF" Then
iProperties.Material= "SF"
ElseIf Parameter("material") = "BP" Then
iProperties.Material= "M2"
ElseIf Parameter("material") = "CB" Then
iProperties.Material= "CB"
As written, when the prompt in the global form is changed to any of these options, the material type does not change.  If I change the rule from an external rule to a local rule and use "material" as a variable it works just fine.  What am I missing?
Thanks!
HermJan.Otterman
Have a look at this link:
https://www.augi.com/articles/detail/playing-by-the-ilogic-rules%20
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
