Macro/ add in to show override dimensions in sketch?
Message 1 of 10
Hello, do you know a way to show which dimension is overrided after opening drawing? In our company we have some old drawing with overrides but we dont know which one and manual opening every dimension would be very.. irrational 😛 Any suggestions ?
Kind regards ^^
Replies (9)
Message 2 of 10
Jesper_S
Hi.
Try this ilogic code.
'-------------Start Of ilogic ------------------------------------------------
' Set a reference to the active document.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
'Define the drawing dims collection
Dim oDrawingDims As DrawingDimension
'Dim oColor As Inventor.Color
Dim oColor As Color
'Prompt user to choose highlight / un-highlight
Dim booleanParam as Object
booleanParam = InputRadioBox("Select an Option", _
"Hightlight Overrides", "Un-Hightlight Overrides", True, Title := "iLogic")
'Loop through all dimensions and set colors
For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions
   If booleanParam = True Then
   'set color to magenta
   oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
   Else
   'set color to black
   oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
   oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
   End If
   If oDrawingDims.HideValue = True _
   Or oDrawingDims.ModelValueOverridden = True Then
   oDrawingDims.Text.Color = oColor
   Else
   End If
Next
'-------------End of ilogic ------------------------------------------------
//Jesper
//Jesper
Message 3 of 10
Many thanks! Works! 🙂
Do you think that I could make that as a rule for every new or ever opened document ?
Message 4 of 10
bradeneuropeArthur
Yes this is possible:
Put then this code into the "After open" event trigger from I-logic.
Dim oColor As Color
   Else
   End If
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 10
Now I should pay off for this... for now I can give you only a Kudos and honest thanks 😛 Its hard to make macro from the first code ?
Message 6 of 10
Jesper_S
Hi.
Do you want it as a button on the ribbon?
Place the iLogic-code as a External rule. Save it as a .txt (notepad) document.
(I cant convert it to VBA)
Place this code in a Module in the VBA-editor.
Public Sub Dimensions()
RuniLogic ("Your iLogic code.txt") 'replace the red text with the name of your external rule
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
Dim iLogicAuto As Object
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
End If
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Public Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
You can now add the a button to the ribbon. Right-click on the ribbon and select "Customaize User Commands"
The macroname will be Dimensions
//Jesper
//Jesper
Message 7 of 10
Thats everything what I needed, and even more beacuse you guided me very well so many thanks to you! I really appreciate you. 🙂
Message 8 of 10
Jesper_S
If you got more external rules, you can easily add them to the ribbon also.
Just add more Public Subs.
Public Sub Button_Name()
RuniLogic ("Rule Name.txt")
End Sub
Public Sub Dimensions()  'No special characters or spaces.
End Sub
Public Sub Button_Name()   'No special characters or spaces.
End Sub
End Sub
Exit Sub
End If
End Sub
addIn.Activate
Exit Function
NotFound:
End Function
//Jesper
Message 9 of 10
Thanks! Wonderful. Can I ask you where did you get these iLogic commands like "DrawingDims.ModelValueOverridden" or "DrawingDims.HideValue" ?
Message 10 of 10
Jesper_S
Hi.
From there and from the Inventor Customization Forum.
//Jesper
//Jesper
