- Mute
- Permalink
- Report
I'm trying to create a For loop with an integer of 1 To 4 using "internal" parameters ("Dim Inlet1 As Double" maybe there's another name for parameters declared inside a rule?). The rule works if I use user parameters but I'd rather not as these parameters are only gonna be used for counting a number of features and adding it all together to an iproperty.
It looks like this:
Dim Inlet1 As Double Dim Inlet2 As Double Dim Inlet3 As Double Dim Inlet4 As Double For i As Integer = 1 To 4 If Not Parameter("Inlet" & i & "Direction") = "Ingen vald" Then Inlet & i = Parameter("Inlet" & i & "Pattern_Num") Else Inlet & i = 0 End If Next iProperties.Value("Custom", "Test") = Inlet1 + Inlet2 + Inlet3 + Inlet4
Best,
Fredrik
