LODs as Multi value list?
nnguyenETKNW
Message 1 of 9
nnguyenETKNW
Hi everyone,
I have a lot of different LODs with the possibility of adding more, I've been searching and I'm now wondering if there was a way to throw all of them into a list to make selecting them neater.
I've had luck throwing appearances into an array and being able to select the various appearances from a list, and I'm interested in being able to do the same with LODs.
I'm aware that upon opening the assembly there is a LOD selector available, but is there one possible while the assembly is already open?
Cheers,
Replies (8)
Message 2 of 9
bradeneuropeArthur
You can simply activate them manually so no code required!
Or am I missing something here?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
nnguyenETKNW
I have been selecting them manually through the design tree so far, however the list is getting long and messy.
What I'm after is being able to have them all in a drop down list, sorted alphabetically, so that I can scroll through in a form.
I came across a similar idea for material appearances which I've also incorporated, but I have no idea how to do it with LoDs. Any help would be greatly appreciated.
Message 4 of 9
bradeneuropeArthur
Tommorow ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
nnguyenETKNW
Absolutely, that would be amazing!
Message 6 of 9
bradeneuropeArthur
This is the VBA Code:
put it into a Userform and add a listbox to it.
Private Sub ListBox1_Click()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim LOD As LevelOfDetailRepresentation
Dim LODS As LevelOfDetailRepresentations
Set LODS = b.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations
LODS.Item(ListBox1.Text).Activate
End Sub
Private Sub UserForm_activate()
For Each LOD In LODS
ListBox1.AddItem LOD.Name
Next
End Sub
I have also uploaded the complete form for you.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 9
nnguyenETKNW
Thank you so much!
I tested out your VBA code and it works perfectly.
I had to make some adjustments to adapt it to my iLogic form but it's working perfectly.
Thanks again, all the best!
Message 8 of 9
bradeneuropeArthur
Your thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
j_weber
Searching for a solution of a german case I found this and it is fantastic.
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
