Load independent add-ins in more than one session of Autodesk Inventor
KOKAK
Message 1 of 31
KOKAK
When I charge a second or third Inventor session to work with more than one project at a time, the Add-ins programmed by me and loaded in these new sessions, always work on the first session of Inventor.
What must be done so that the Add-ins of each Inventor session are independent and work each one with their corresponding Inventor session.
Replies (30)
Message 2 of 31
bradeneuropeArthur
Where did you store the dll files on you machine?
Where did you store the addin files on you machine?
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 31
KOKAK
Thanks for answering.
both the dll files and the addin files are stored in the folder
Message 4 of 31
KOKAK
Both the DLL files and the add-in files are stored in the folder C: \ Datos de programa \ Autodesk \ Inventor complementos
Message 5 of 31
bradeneuropeArthur
use the following
C:\ProgramData\Autodesk\Inventor 20xx\Addins >> : for the add in file
C:\Program Files\Autodesk\Inventor 20xx\Bin>> : for the dll file
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 31
KOKAK
Sorry. Problems with the simultaneous translation of the browser.
Both the DLL files and the addin files are stored in the folder C:\ProgramData\Autodesk\Inventor Addins
Following its indications I have copied the .addin files in the folder C: \ ProgramData \ Autodesk \ Inventor 2019 \ Addins and the dll files in the folder C: \ ProgramData \ Autodesk \ Inventor 2019 \ Addins.
However, the same thing still happens: I open two Inventor sessions and in both cases my add-on programs refer to the files (ipt, iam, idw) active in the initial session and not those in the second.
Message 7 of 31
KOKAK
I correct:
The dll files I have copied in C: \ Program Files \ Autodesk \ Inventor 2019 \ Bin
Message 8 of 31
KOKAK
An example:
I open an Inventor session ("A") and load an idw ("1").
I open another session of Inventor ("B") with another different project, and charge another idw ("2").
Now I execute a program of mine that centers all the dimension texts.
If I execute it in ("A"), all the decentered dimensions are centered in the drawing ("1").
If I execute the program in ("B"), the dimensions of the drawing ("2") are not centered but those of the drawing ("1") open in ("A").
Message 9 of 31
bradeneuropeArthur
Don't copy it. But move it to the correct folders.
Could you upload the add.in file with the settings. This is actually an xml file.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 31
KOKAK
I have moved the dll files to C: \ Program Files \ Autodesk \ Inventor 2019 \ Bin and the manifest Addin files to C: \ ProgramData \ Autodesk \ Inventor 2019 \ Addins and it still gives me the same result: all my complements are executed on the first open session of Inventor although they are of other later sessions.
The manifest Addin files follow the following structure:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<Addin Type="Standard">
  <!--Created for Autodesk Inventor 2014 (Version 18.0)-->
  <ClassId>{3d2c19c3-1e12-4681-8bb5-88aad094e388}</ClassId>
  <ClientId>{3d2c19c3-1e12-4681-8bb5-88aad094e388}</ClientId>
  <DisplayName>SampleAddIn</DisplayName>
  <Description>SampleAddIn</Description>
  <Assembly>SampleAddIn.dll</Assembly>
  <SupportedSoftwareVersionGreaterThan>21..</SupportedSoftwareVersionGreaterThan>
  <LoadAutomatically>0</LoadAutomatically>
  <LoadOnStartUp>1</LoadOnStartUp>
  <LoadBehavior>2</LoadBehavior>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
</Addin>
Message 11 of 31
bradeneuropeArthur
What I can figure out is the following:
change this to
<LoadBehavior>0</LoadBehavior>
or delete this line..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 31
bradeneuropeArthur
and this:
change it to
<LoadAutomatically>1</LoadAutomatically>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 31
bradeneuropeArthur
These are the most common settings for the xml file:
<!--Created for Autodesk Inventor Version xx.0-->
<ClassId>{51e6ad8e-5eaa-42a1-b845-a68802a26bf7}</ClassId>
<ClientId>{51e6ad8e-5eaa-42a1-b845-a68802a26bf7}</ClientId>
<OSType>Win64</OSType>
<Hidden>0</Hidden>
<SupportedSoftwareVersionGreaterThan>yy..</SupportedSoftwareVersionGreaterThan>
<DataVersion>1</DataVersion>
<UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 31
KOKAK
<LoadBehavior > 2 (Load when an assembly document is opened)
Message 15 of 31
bradeneuropeArthur
Is that what you need?
but more important:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 31
KOKAK
I have configured all the addins files with <LoadAutomatically> 1 </ LoadAutomatically> but all the complements on the first session are still running.
I do not know whether the topic will have to do with the addin manifest files.
Message 17 of 31
bradeneuropeArthur
What do you mean with
"but all the complements on the first session are still running."
can you upload your code?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 31
KOKAK
Excuse my bad English.
I mean that the complements of the second or third Inventor session do not run in their corresponding session, but in the first Inventor session loaded.
Message 19 of 31
bradeneuropeArthur
Then you use the wrong application in your add in. How do you get your inventor application?
Upload your code and I will figure this out. I think that this is the issue and can be solved simply.
Regards.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 31
KOKAK
I created the Addins for Inventor using the template "Autodesk Inventor 2016 Addin" included in the SDK. Later I follow the structure created, so I do not know if there is something to modify.
