Check if Dimension is horizontal or vertical Orientation via API
Hi everyone,
is there a quick way to check, if a linear dimension is horizontal or vertical?
Maybe via the text orientation?
Greetings
Passi
basnederveen
Yes, you can check if
LinearGeneralDimension.DimensionType = kVerticalDimension / kHorizontalDimension
if this does not work out you could check the dim.IntentOne or dim.IntentTwo and see if the difference in PointOnSheet X/Y corresponds to the modelvalue of the dimension
Thanks a lot, the "Lineargeneraldimesion" was the hint 🙂
