Get Drawing dimensions of specific views via api
Hi everyone,
I'm trying to get all dimensions inside a specific view.
I already have all general dimensions in the complete drawing, but I only want to change the dimensions of a specific view.
I don't know, where to check, if its a dimension of view A or view B.
Should be easy I think, but I haven't found yet.
Greetings
basnederveen
You can check
Dim oview as DrawingView
Set oview = LinearGeneralDimension.IntentOne.Geometry.Parent
Yep, that works, thanks a lot.
sellvakumarmech
Holo..
The above code is working fine. it was great..:) but not able to get the dimensions form (retrieve model dimensions) model.
Is there any way to get dimension based on view in a sheet..?. (i want to add sketch symbol for views basic, so i like to select the dimensions based on the views.)
Note: Kindly guide me the right way. if anything wrong with my approach..
Thanks in advance.
Selvakumar
basnederveen
I am sorry i do not really understand what you mean. Do you want to use retrieve model dimensions and create sketchpoints or do you want to add actual dimensions to the model?
sellvakumarmech
Hey,
sorry for the late response..
I just trying to get the all dimensions text coordinated in .idw file based on the views.
user Need to select a view and the loop returns an array of dimension text coordinates
as code follows,
for each oview in doc.activesheet.views
      for each odimension in doc.activesheet.oview.dimensions.
          arrayofdimcoordinated(i) = odimension .text.origin.x
          arrayofdimcoordinated(i) = odimension .text.origin.y
      next
Next
could you plesae help me ot find the dimensions for selected view.
thanks in advance.
Selvakumar V
