listing browser pane folder items
NachoShaw
Advisor Advisor
NachoShaw
Hi
How can i loop through the browser panel and list only the nodes that are inside a specific folder?
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
MechMachineMan
By writing code to do such a thing? The relevant inventor objects are all found under the BrowserPane object.
You need to go:
BrowserPane > TopNode > BrowserFolders > BrowserNode > BrowserNodes > objects in folder.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-9F6FC721-CCCB-4EA2-92D1-694DC5B12C22
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
CattabianiI
Hi @NachoShaw,
I attached to this question a piece of code to print out the ModelBrowserPane tree considering occurrences and user's folders.
You should do your stuff instead of printing the name of the node and add something like these code's lines in the PrintModelNodeNameRec function:
If browserNode.NativeObject.Type = ObjectTypeEnum.kBrowserFolderObject AndAlso
browserNode.NativeObject.Name <> "MyFolderName" Then
Return
CattabianiI wrote:
Here the iLogic code to print the ModelBrowserPane tree as in the image on the right:
SyntaxEditor Code Snippet
Class TraverseBrowserPaneRule
    Const printedTreeFfn As String = "c:\temp\modelBrowser.txt"
    Sub Main()
        Dim modelBrowserPane As BrowserPane = ThisApplication.ActiveEditDocument.BrowserPanes.Item("AmBrowserArrangement")
        Dim topNode As BrowserNode = modelBrowserPane.TopNode
        Using sw As IO.StreamWriter = IO.File.CreateText(printedTreeFfn)
            sw.WriteLine(ThisApplication.ActiveEditDocument.DisplayName )
        End Using
        PrintModelNodeNameRec(topNode, 0)
    End Sub
    Sub PrintModelNodeNameRec(browserNode As BrowserNode, level As Integer)
        Dim name As String
        If browserNode.NativeObject IsNot Nothing AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kBrowserFolderObject  _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kComponentOccurrenceObject _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kComponentOccurrenceProxyObject _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
            Return
        Try
            name = browserNode.NativeObject.Name
        Catch ex As Exception
            'name = browserNode.FullPath
        End Try
        If Not String.IsNullOrEmpty(name) Then
            Using sw As IO.StreamWriter = IO.File.AppendText(printedTreeFfn)
                sw.WriteLine(Space(level*2) + name)
            End Using
        For Each node As BrowserNode In browserNode.BrowserNodes
            PrintModelNodeNameRec(node, level + 1)
        Next
        Return
    End Sub
End Class
I do not want Product software
ด้วยความนับถือ
นายคอฟิซ ดือราโอ๊ะ
เบอร์ 086-9891885 หรือ 094-3534884
โทรได้ตลอด 24 ชั่วโมง
