GoExcel.NameRange ERROR: Public member 'GetLength' on type 'String' not found.
I'm trying to update a MultiValue List using GoExcel.NameRangeValue in iLogic.
So far all worked well, when the name range had more than one row But getting an error: "Public member 'GetLength' on type 'String' not found." when that Range has less than two rows.
I'm a not a VBA coder by any stretch of the imagination but have dabbled in coding in other languages. I've used a code snippet from Xiaodong Liang that gets the job done when ranges are => 2 rows
Any help would be appreciated.
Here is my code:
SyntaxEditor Code Snippet
GoExcel.Open("CabSpecBook.xlsx", "Wall Cabinets")
'Code Snipet to read Name Range in Excel
    'this Is an array X*Y dimension
    rangeArray = GoExcel.NamedRangeValue("_15inHW1D")
    'create a list to get the values of the columns
    Dim oList As ArrayList
    oList = New ArrayList
    'rangeArray.GetLength(0)  means how many rows
    'rangeArray.GetLength(1)  means how many colmuns
    Dim oRowsCount
    oRowsCount = rangeArray.GetLength(0)
    Dim oColCount
    oColCount = rangeArray.GetLength(1)
    Dim oRowIndex As Integer
    Dim oColIndex As Integer
    For oRowIndex = 1 To oRowsCount
    ' add value of each row one by one
    For oColIndex = 1 To oColCount
        oList.Add(rangeArray(oRowIndex,oColIndex))
    Next
    Next
    'Set it To the list Parameter
    MultiValue.List("CabModNum") = oList
iLogicVb.UpdateWhenDone = True
Xun.Zhang
Hi, Try this.
    Dim oRowsCount
    Dim oColCount
    Dim oRowIndex As String
    Dim oColIndex As String
    Next
    Next
Xun
Thanks for the follow-up.
I went over the code all night and it's the same as the previous one I had posted.
Mid going through the changes that were made in case I'm missing something?
Thank you
kelly.young
Autodesk Support
Autodesk Support
@Anonymous the change I can see is that Integer is changed to String:
Please select the Accept as Solution button if a post solves your issue or answers your question.
Good morning,
This is the error I get when I run string instead of integer:
Error on Line 28 : 'For' loop control variable cannot be of type 'String' because the type does not support the required operators.
Error on Line 30 : 'For' loop control variable cannot be of type 'String' because the type does not support the required operators.
sorry for the late reply
