Linking parameters to existing derived parameter table crashes
johnster100
johnster100
i have two parts, part 1 and part2.
Part 2 is already linked to part 1. I would like to link an extra parameter (d3 in this case) to it.
i have followed the sample in the help guide but can't get to work.
here is my code and the parts are attached with the code in part 2:
Sub main
	Dim param As String = "d3"
	Dim oCompDef As Inventor.PartComponentDefinition = ThisDoc.Document.ComponentDefinition
	Dim oLinkedPart As Inventor.PartDocument
	Dim oTable As Inventor.DerivedParameterTable = oCompDef.Parameters.DerivedParameterTables.Item(1)
	Dim oParamsToLink As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	'oParamsToLink  = oTable.DerivedParameters
	For Each oPAram In oTable.LinkedParameters
		oParamsToLink.Add(oPAram)
	Next
	oLinkedPart = oTable.ReferencedDocumentDescriptor.ReferencedDocument
	oParamsToLink.Add(oLinkedPart.ComponentDefinition.Parameters.Item(param))
	oTable.LinkedParameters = oParamsToLink
End Sub
any help greatly appreciated,
thanks,
John
bradeneuropeArthur
If you used the derive method to make a link to the other part, you will need to use here also the derive method to derive a parameter.
Think that you cannot mix both!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
johnster100
thanks for that!
i'll look into it.
Ralf_Krieg
Hello
As I see in your demo files, the parameters are linked, not derived.  The only little fault in your code is, you can not add the linked parameters to the object collection of parameters to linked. You need to add the original parameters. Try:
Sub main()
    Dim oCompDef As Inventor.PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oTable As Inventor.DerivedParameterTable= oCompDef.Parameters.DerivedParameterTables.Item(1)
    Dim oLinkedPart As Inventor.PartDocument = oTable.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oParam As DerivedParameter
    Dim oSourceParam As Parameter
    For Each oParam In oTable.LinkedParameters 'returns a DerivedParameter, we need the source
        For Each oSourceParam In oLinkedPart.ComponentDefinition.Parameters
            If oSourceParam.Name = oParam.Name Then Call oParamsToLink.Add(oSourceParam)
        Next
    Next
    Call oParamsToLink.Add(oLinkedPart.ComponentDefinition.Parameters.Item(param))
End Sub
 o
R. Krieg
RKW Solutions
www.rkw-solutions.com
Ralf_Krieg
In addition, if the part is derived  instead linked, the parameter could included like this:
Sub main()
    Dim oDerivedPartComp As DerivedPartComponent = oTable.ReferenceComponent
    Dim oDerivedPartDef As DerivedPartUniformScaleDef= oDerivedPartComp.Definition
    Dim oParam As DerivedPartEntity
    For Each oParam In oDerivedPartDef.Parameters
        If oParam.ReferencedEntity.Name = param Then
            oParam.IncludeEntity = True
    Next
    oDerivedPartComp.Definition = oDerivedPartDef
End Sub
R. Krieg
RKW Solutions
