Delete Weld Symbols on drawing in Inventor 2018 with iLogic
MESZ.CIDEON
MESZ.CIDEON
Hey Folks,
is it possible to delete weld symbols on a drawing with iLogic? I saw ideas to make it possible in API, but I want to ask however.
Best Regards, Mike
WCrihfield
I don't think it's possible right now.  Maybe in the future though.  Here is a link to another recent similar post that was responded to by an Autodesk employee.  For now, I would suggest that you follow the link provided on that post to vote for that idea on the idea station (and maybe search for other similar/related ideas, to up-vote).
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
JMGunnar
Inventor API not support weld symbol
but you can use custom filter
to only select weld symbol
Johan
WCrihfield
Good point @JMGunnar.  Using that could make the manual process go quicker.
@MESZ.CIDEON
  This is a similar situation to the Revision Tags.  There is a manual filter you can set to be able to select them manually, but no API object support for them yet.  Here is an idea I posted to get the Revision Tag supported & recognized in the API.  If you agree, please up-vote it.  And you can search for a similar idea for the Weld Symbol in there.  If you don't find one, you could create one, then add a link to it back here.  There are other like that too.
Wesley Crihfield
