Link parameters with iLogic
kresh.bell
Message 1 of 13
kresh.bell
could someone make me an iLogic that would do the following when run it:
- I have the "LW" parameter in the assembly environment (it never changes its name).
- after iLogic is run, I would like it to open win explorer in the assembly location
- after that, I would like select the part in whose parameters is the driven dimension whose value I want to link with the "LW" parameter
- is it possible that after selecting that driven dimension, iLogic automatically links it with the "LW" parameter?
thanks
Replies (12)
Message 2 of 13
bradeneuropeArthur
Sure. Keep reading....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
bradeneuropeArthur
do you prefer an add-in or via i-logic or VBA?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 13
kresh.bell
thanks for reply, iLogic I think
Message 5 of 13
bradeneuropeArthur
let me program quickly...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 13
bradeneuropeArthur
what is the name of the paramater to link to?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 13
kresh.bell
it is not always the same
Message 8 of 13
bradeneuropeArthur
Like this:
Dim a As Inventor.AssemblyDocument = ThisAssembly.Document
Dim p As Inventor.Parameter = a.ComponentDefinition.Parameters.Item("LW")
p.ExposedAsProperty = True
Dim d As Inventor.FileDialog
ThisApplication.CreateFileDialog(d)
Dim fio As New System.IO.FileInfo(a.FullFileName)
Dim dio As New System.IO.DirectoryInfo(fio.DirectoryName)
msgbox(dio.FullName)
d.InitialDirectory = dio.FullName
d.Filter = "[*ipt]"
d.MultiSelectEnabled = False
d.ShowOpen
Dim prt As Inventor.PartDocument = ThisApplication.Documents.Open(d.FileName, True)
Dim pc As Inventor.PartComponentDefinition = prt.ComponentDefinition
pc.Parameters.DerivedParameterTables.Add2(a.FullFileName)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 13
kresh.bell
Thanks, but maybe we didn't understand each other, I would like the option to select a parameter for the link, not to open the part where that parameter is located
Message 10 of 13
bradeneuropeArthur
Could you add some more screenshots or explain step by step, because I think indeed I don't understand what you exactly need.
Best Regards,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
kresh.bell
Open assembly parameters, click link
select part file in same folder where is assembly
in that part select parameter for link
in assembly, add parameter from part to parameter LW in assembly
Message 12 of 13
kresh.bell
nobody have idea about this?
Message 13 of 13
A.Acheson
Hi @kresh.bell
@bradeneuropeArthur got you to the point of adding the derived parameter table and what you need now is to add the parameter. See API help for adding table and the sample for adding the parameter.
Regards
Alan
