ilogic to turn on tangent and interface edges
JacobRL4SN
JacobRL4SN
Has anyone written ilogic to turn on tangent and interface edges for all views? Or have a way to make it default turned on?
WCrihfield
Hi @JacobRL4SN.  Yes, that is possible.  The DrawingView API object has those properties that can be turned on and off by code.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=DrawingView_DisplayInterferenceEdges
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=DrawingView_DisplayTangentEdges
Do you have a starter code you are working with already?  If so, could you post what you have, then we can try to update it for you.  Otherwise please include more details about the situation, such as how you want to tell the code which view for it to target (every view on every sheet of the drawing, just one specific view, just the first view on the first sheet, etc, etc).
Edit:  Below is an example iLogic rule you can try out.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
	Exit Sub
Dim oDDoc As DrawingDocument = ThisDoc.Document
If oDDoc.IsModifiable = False Then Exit Sub
Dim oSheets As Inventor.Sheets = oDDoc.Sheets
For Each oSheet As Inventor.Sheet In oSheets
	Dim oViews As DrawingViews = oSheet.DrawingViews
	If oViews.Count = 0 Then Continue For
	For Each oView As DrawingView In oViews
		Try
			oView.DisplayInterferenceEdges = True
			oView.DisplayTangentEdges = True
		Catch
		End Try
	Next
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
JacobRL4SN
Hi @WCrihfield,
I do not have any starter code written new to ilogic. I would want the ilogic to target every view on every sheet to turn on tangent and interface edges.
JacobRL4SN
My hero thank you!
