LevelOfDetailRepresentation
GeorgK
Advisor Advisor
Message 1 of 18
GeorgK
Hello together,
I am looking for a possibility to list all parts, assemblies and subassemblies which are suppressed by a LevelOfDetailRepresentation.
This works for an assembly without subassemblies:
Dim asm As AssemblyDocument
        asm = m_inventorApplication.ActiveDocument
        Dim acd As AssemblyComponentDefinition
        acd = asm.ComponentDefinition
        Dim rm As RepresentationsManager
        rm = acd.RepresentationsManager
        Dim nvm As NameValueMap
        nvm = m_inventorApplication.TransientObjects.CreateNameValueMap()
        Dim doc As AssemblyDocument
        Dim occ As ComponentOccurrence
        ListBox1.Items.Clear()
        ListBox2.Items.Clear()
        Dim lod As LevelOfDetailRepresentation
        For Each lod In rm.LevelOfDetailRepresentations
            ListBox1.Items.Add(lod.Name)
            ListBox2.Items.Add(lod.Name)
            Call nvm.Add("LevelOfDetailRepresentation", lod.Name)
            doc = m_inventorApplication.Documents.OpenWithOptions(asm.FullFileName, nvm, False)
            Call nvm.Clear()
            For Each occ In doc.ComponentDefinition.Occurrences
                If occ.Suppressed = True Then
                    ListBox2.Items.Add("    " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
                End If
                ListBox1.Items.Add("    " + occ.Name + " Suppressed = " + Str(occ.Suppressed))
            Next
            ' Don't forget to close the document not used anymore
            If Not lod Is rm.ActiveLevelOfDetailRepresentation Then
                Call doc.Close(True)
            End If
        Next
Thank you very much
Georg
Replies (17)
Message 2 of 18
MechMachineMan
This is only going to work for the top level of the active document as you dont have anywhere in your program that tells it to go any deeper.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 18
GeorgK
Hello Justin,
please could you help me? How could I get the suppressed parts and assemblies from subassemblies?
Thank you Georg
Message 4 of 18
RodrigoEiras
In the Programming/API help there is an example about how to traverse an assembly. I think that's what you need to add to your code.
I paste it below:
Traverse an Assembly API Sample
Public Sub AssemblyCount()
    ' Set reference to active document.
    ' This assumes the active document is an assembly
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get assembly component definition
    Dim oCompDef As Inventor.ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim sMsg As String
    Dim iLeafNodes As Long
    Dim iSubAssemblies As Long
    ' Get all occurrences from component definition for Assembly document
    Dim oCompOcc As ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        ' Check if it's child occurrence (leaf node)
        If oCompOcc.SubOccurrences.Count = 0 Then
            Debug.Print oCompOcc.Name
            iLeafNodes = iLeafNodes + 1
        Else
            iSubAssemblies = iSubAssemblies + 1
            Call processAllSubOcc(oCompOcc, _
                                sMsg, _
                                iLeafNodes, _
                                iSubAssemblies) ' subassembly
        End If
    Next
    Debug.Print "No of leaf nodes    : " + CStr(iLeafNodes)
    Debug.Print "No of sub assemblies: " + CStr(iSubAssemblies)
End Sub
' This function is called for processing sub assembly.  It is called recursively
' to iterate through the entire assembly tree.
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, _
                             ByRef sMsg As String, _
                             ByRef iLeafNodes As Long, _
                             ByRef iSubAssemblies As Long)
    Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If oSubCompOcc.SubOccurrences.Count = 0 Then
            Debug.Print oSubCompOcc.Name
        Else
            sMsg = sMsg + oSubCompOcc.Name + vbCr
            Call processAllSubOcc(oSubCompOcc, _
                                  sMsg, _
                                  iLeafNodes, _
                                  iSubAssemblies)
        End If
    Next
End Sub
I hope that's what you need
Message 5 of 18
GeorgK
Hello Rodrigo,
thank you very much for the code. The problem is to get the dependent representations from the main assembly and loop than througt the assembly.
Main.iam -> LOD1 ; LOD2 ; LOD3
SUB1.iam -> LOD1 ; LOD2 ; LOD3
SUB2.iam -> LOD1 ; LOD2 ; LOD3
Georg
Message 6 of 18
RodrigoEiras
Hi Georg,
I see that the difficulty lies in trying to get the LODs from the subassemblies, as you cannot do it from the ComponentOcurrence, but probably you would have to access each subassembly individually to be able to use the RepresentationsManager object and get the LODs.
Unfortunately I am not so experienced in this kind of programming with assemblies, so I am afraid I cannot help you further with this issue.
Good luck!
Message 7 of 18
MechMachineMan
I could see this getting pretty interesting depending on how things are suppressed as if you suppress components in a lower level, it will make it a temporary level of detail, thus you will have to search through those to access parts.
You might have an easier time just listing all suppressed parts for the current state of the top-level assembly document, by ignoring the level of detail aspect completely and just testing suppression status.
Otherwise, I would say you will definitiely need to look into the RepresentationsManager.LevelofDetailRepresentations methods.
Looking at all of the methods under Level Of Detail representations, the most use it will be for you is to establish what LOD you are looking at, and chaning/traversing them. They dont contain any information about the suppression status of components, only the substitute parts that may be used instead.
Justin K
Message 8 of 18
Vladimir.Ananyev
I've slightly changed the code of thr "Traverse an Assembly API Sample".
Now it prints names of suppressed components ignoring substitutes.
You may extend this code to loop through every LOD in your top assembly document.
    Dim sMsg As String
    Debug.Print "--- Assembly: " & oDoc.DisplayName
        If Not oCompOcc.IsSubstituteOccurrence Then
            If oCompOcc.Suppressed Then
                Debug.Print "suppressed:  " & oCompOcc.Name
            Else
                    'empty SubAssembly - do nothing
                Else
                                        sMsg, _
                                        iLeafNodes, _
                End If
            End If
        End If
    Next
    Debug.Print
    Debug.Print "No of suppressed nodes : " + CStr(iLeafNodes)
    Debug.Print "No of sub assemblies   : " + CStr(iSubAssemblies)
End Sub
    Debug.Print "--- SubAssembly: " & oCompOcc.Name
        If Not oSubCompOcc.IsSubstituteOccurrence Then
            If oSubCompOcc.Suppressed Then
                Debug.Print "suppressed:  " & oSubCompOcc.Name
            Else
                Else
                                          sMsg, _
                                          iLeafNodes, _
                                          iSubAssemblies)
                End If
            End If
        End If
    Next
End Sub
 Hope this helps.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 9 of 18
GeorgK
Hello Vladimir,
thank you very much for your help.
Georg
Message 10 of 18
arge
hi
Can you help me  for  total Item QTY
Message 11 of 18
Vladimir.Ananyev
Try this sample please:
Sub BOM_Qty_Test()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oBOM As BOM
    Set oBOM = oAsmDoc.ComponentDefinition.BOM
    oBOM.StructuredViewEnabled = True
    oBOM.StructuredViewFirstLevelOnly = True
    Dim oBOMView As BOMView
    Set oBOMView = oBOM.BOMViews.Item("Structured")  'Structured
    Dim oBOMRow As BOMRow
    Dim TotalQty As Double
    TotalQty = 0
    For Each oBOMRow In oBOMView.BOMRows
        TotalQty = TotalQty + oBOMRow.TotalQuantity
        Debug.Print "ItemNumber = " & oBOMRow.ItemNumber & "    Qty = " & oBOMRow.TotalQuantity
    Next
    Debug.Print "Total Qty = " & TotalQty
    Beep
End Sub
BOMRow.TotalQuantityOverridden Boolean property could help you to detect if the TotalQuantity property has been overridden.
cheers,
Vladimir Ananyev
Message 12 of 18
arge
hi Vladimir
Thanks for answer but ı need total ItemQTY (sum ItemQTY) in BOM
not Total QTY
Message 13 of 18
Vladimir.Ananyev
Then use BOMRow.ItemQuantity property.
You may look at the BOMQuery vba sample from the Inventor API Help.
cheers,
Vladimir Ananyev
Message 14 of 18
arge
thanks
its ok
Message 15 of 18
arge
thanks  for your help..
Can ı another quession?
how do   "user parameter"  = Base Quantity  in part
Message 16 of 18
Vladimir.Ananyev
Look at the following post:  Use iLogic to Change Base Quantity
http://forums.autodesk.com/t5/inventor-customization/use-ilogic-to-change-base-quantity/m-p/3222896/...
See Inventor API Help for the BOMQuantity.GetBaseQuantity method.  It allows to retrieve the base quantity for the part.  If the first argument is BOMQuantityTypeEnum.kParameterBOMQuantity then the second argument returns the parameter object.  You can get parameter name to use it in your rule.
Vladimir Ananyev
Message 17 of 18
arge
I want to use this way
iProperties.Value("Custom", "HAMMADDE MALİYET") = (iProperties.Value("Custom", "HAMMADDE KODU"))*(BaseQuantity)*1.05
Message 18 of 18
arge
Can you help me this  topic?
" I want to use this way
iProperties.Value("Custom", "HAMMADDE MALİYET") = (iProperties.Value("Custom", "HAMMADDE KODU"))*(BaseQuantity)*1.05    "
