Is there a way to set a sketch command as a shortcut? (Pointsnap Midpoint)
- Mute
- Permalink
- Report
So I do a lot of elevations for work that involve needing to sketch over cabinets and mark door opening direction marks. So far, the easiest way I've found to make these is with the 'Select Midpoint" on the Line commands Point Snap option. Is there a way I can make some kind of shortcut through ilogic or vba to make this process faster? Or maybe a setting inside inventor that only selects End & Midpoints?
