ilogic check out all open active documents only check the one showing on the screen
j.wang4QB4L
j.wang4QB4L
M1 = MessageBox.Show("Do you want to check Out all open files?", "Vault Check-out", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
If M1 = vbYes Then
	Dim oDoc As Inventor.Document
	Dim docs As Documents
	docs = ThisApplication.Documents
	For i = 1 To docs.VisibleDocuments.Count
		oDoc = docs.VisibleDocuments.Item(i)
		'invoke Check In dialogbox
		ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop").Execute2(False)
	Next
	MessageBox.Show("Vault Check-out Complete!!!!", "Vault Check-out")
Else
	MessageBox.Show("Not Successful!!!!","Vault Check-out")
Return
This is the ilogic I want to use for checking out all the open visible files. But it only check out one file from vault and the stop to proceed the rest.
Could anyone have a look and help me fix it?
jeremy.goenen
Hello, one possibility could be that Inventor does not have Time to Checkout the File before you jump to the next, to test if thats the case:
Set your execute2 to True, so your rule waits for Dialogs to dismiss first, and then add a sleep instruction right after that
System.Threading.Thread.CurrentThread.Sleep(5000) 'time in milliseconds
If this solves the issue, you can shorten the sleep instruction to a point where you can safely assume the Checkout has been completed.
Another possibility: Which Document will the Command be
Executed on? (I dont know the Command behavior, and there is no Document specification) Is it only the Active one that gets checked out?
If Yes,
I assume it behaves the same as Clicking the CheckoutButton in the Toolbar, which will  Act for the currently Active, or Preselected Documents. In this case i suggset you Activate the Documents first, before calling the Checkout Command.
Fanden Sie diesen Beitrag hilfreich? Fühlen Sie sich frei, diesen Beitrag zu liken.
Wurde Ihre Frage erfolgreich beantwortet? Klicken Sie dann auf die Schaltfläche LÖSUNG AKZEPTIEREN
Inventor Versionen:
2025.2
jeremy.goenen
i just run a test and here the result, add the Bold Red Line to you code and it should work, this will switch ActiveDocument before Calling the CheckoutCommand
		docs.Open(oDoc.FullFileName,True)
Inventor Versionen:
2025.2
WCrihfield
TIP:  Instead of using Documents.Open() method on a document that is already open, and specifying FullFileName, which may contain as much info as FullDocumentName...try using Document.Activate method instead (oDoc.Activate), because you already have the Document object (oDoc).
Wesley Crihfield
(Not an Autodesk Employee)
jeremy.goenen
That would be the proper way to do it, but it wasn't showing up in my Methods list.
Inventor Versionen:
2025.2
