Is it a bug in Inventor professional 2022 ?
Message 1 of 15
What is the reason? (In Inventor Professional 2022)
Run In (VBA Editor F5).
But
Doesn't run in (Customize ShortCut Key '4')
What is the reason?
Public Sub CollapseAll() 'Set ShortCut Key = 4
Dim oCommandMgr As CommandManager
Set oCommandMgr = ThisApplication.CommandManager
Dim oControlDef As ControlDefinition
Set oControlDef = oCommandMgr.ControlDefinitions.Item("AppBrowserCollapseAllCmd")
Call oControlDef.Execute
ThisApplication.ActiveDocument.Update
End Sub
Replies (14)
Message 2 of 15
bradeneuropeArthur
What is the problem precisely?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
laszlo_nagy
this code doesn't work me neither in Inventor 2022
I think there is an issue with the internal command
maybe try this code, it traverses through the browsernodes and close them one by one
Public Sub closeAll()
    Dim oDoc  As Document
    Set oDoc = ThisApplication.ActiveDocument
    Dim oModelPane As BrowserPane
    Set oModelPane = oDoc.BrowserPanes.Item("Model")
    Dim oTopNode As BrowserNode
    Set oTopNode = oModelPane.TopNode
    Dim oNode As BrowserNode
    For Each oNode In oTopNode.BrowserNodes
        Call closeNodes(oNode)
    Next
End Sub
Private Sub closeNodes(ByRef oNode As BrowserNode)
    If oNode.BrowserNodes.Count <> 0 Then
        Dim oChildNode As BrowserNode
        For Each oChildNode In oNode.BrowserNodes
            Call closeNodes(oChildNode)
        Next
    End If
    On Error Resume Next
        oNode.Expanded = False
    On Error GoTo 0
End Sub
Message 4 of 15
dg2405
On my Inventor 2022 this code works!
Message 5 of 15
dg2405
Sorry with press key 4 it also don't work here.
Message 6 of 15
Thank you, but it's too slow.
Message 7 of 15
A.Acheson
@Anonymous
I tested this in inv 2020 and it worked. Unfortunately I could not test in 2022.
Is there a chance this keyboard key his used elsewhere on your installation?
Also if you would like to bump the forum post to the top to ensure it gets noticed, under options click float this item to the top. Creating multiple post with the same content can be confusing for users looking to answer the question and for future users looking for a direct single source answer.
Regards
Alan
Message 8 of 15
bradeneuropeArthur
@A.Acheson
A question beside.
Where to find that option float to top?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 15
A.Acheson
@bradeneuropeArthur @Anonymous
My apologies!!, that button does not float the post to the top but rather pins it to the top which is maybe not the correct use of the button. The only other way I would think is to comment on your own post.
Regards
Alan
Message 10 of 15
bradeneuropeArthur
@A.Acheson
It would be a good option to have the possibility to move topics up, but if everyone uses this.......
Otherwise we could add it to the Idea Station, but it will make no sense!
Thanks for the hint anyway.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 15
Ralf_Krieg
Hello
This button pins the thread only for yourself. Pin for all users is a function only for moderators or administrators.
In Inventor 2022 it seems to make a difference where mouse cursor is positioned when hitting shortcut key. If it is above model browser, it works. So I thought of moving mouse to model browser in macro and back to original position. Can you give it a try?
Option Explicit
Private Declare PtrSafe Function SetCursorPos Lib "user32.dll" (ByVal X As Integer, ByVal Y As Integer) As Integer
Private Declare PtrSafe Function GetCursorPos Lib "user32" (ByRef lpPoint As POINTAPI) As Long
Public Declare PtrSafe Sub mouse_event Lib "user32" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal cButtons As Long, ByVal dwExtraInfo As Long)
Public Const MOUSEEVENTF_MOVE = &H1
Private Type POINTAPI
    X_Pos As Long
    Y_Pos As Long
End Type
Private Sub MoveMouse()
    Dim X As Integer
    X = ThisApplication.UserInterfaceManager.DockableWindows.Item(1).Left + ThisApplication.UserInterfaceManager.DockableWindows.Item(1).Width - 50
    Dim Y As Integer
    Y = ThisApplication.UserInterfaceManager.DockableWindows.Item(1).Top + ThisApplication.UserInterfaceManager.DockableWindows.Item(1).Height - 50
    Dim i As Integer
    i = SetCursorPos(X, Y)
    Call mouse_event(MOUSEEVENTF_MOVE, -100, -100, 0, 100)
End Sub
    Dim Coords As POINTAPI
    Call GetCursorPos(Coords)
    Call MoveMouse
    DoEvents
    Call SetCursorPos(Coords.X_Pos, Coords.Y_Pos)
End Sub
Public Sub ExpandAll() 'Set ShortCut Key = 5
    Call MoveMouse
    DoEvents
    Set oControlDef = oCommandMgr.ControlDefinitions.Item("AppBrowserExpandAllCmd")
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 12 of 15
It works fine.
Thank yoy.
Message 13 of 15
Thank you.
Message 14 of 15
cnoJTCG6
Nice solution Krieg for this problem.
I ran into the same thing for some macros after moving to IV2022.
After collapsing the Browser Pane I set a few nodes, 'Model States', 'Representations-View and Position' and 'Origin', back to expanded.
I now do that through a 2nd and 3th For Next loop inside the first one who is checking 'node.FullPath' for a specific string.
In some cases, depending on the size of the Assembly, this takes quite some time.
Is it possible to directly access these nodes?
Message 15 of 15
checkcheck_master
This time on my previously used account:
